6 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.37782
Background
The Craftsman Walk Behind Mower 917.377820 is a gas-powered lawn mower produced by Sears. It's a self-propelled unit, equipped with a 7.0 HP Briggs & Stratton 128602-0304-E1 engine. The mower can hold up to 1.6 quarts of unleaded gasoline and requires 20 ounces of SAE 30 or 5W30 oil. The mower has a 21-inch cutting width and offers a cutting height ranging from 1 to 3.5 inches, with options for six different adjustments. It features a recoil starter and a variable speed front wheel drive transmission system. The blade torque of the mower is between 35-40 ft-lbs.
The mower has a steel 21-inch cutting deck and a front-wheel drive system with variable speed control. It gives users the option to mulch, bag, or side discharge grass clippings. The mower also features a single point height adjustment lever and a folding handle for compact storage. Regular maintenance, such as changing the engine oil every 25 hours of use, cleaning or replacing the air filter annually, replacing the spark plug annually, sharpening or replacing the blade as needed, and cleaning under the mower deck to remove grass buildup, can help ensure reliable use of this mower for home lawn care.
Technical Specifications
- Engine: 7.0 HP Briggs & Stratton 128602-0304-E1
- Fuel Capacity: 1.6 quarts unleaded gasoline
- Oil Type: SAE 30 or 5W30
- Oil Capacity: 20 ounces
- Cutting Width: 21 inches
- Cutting Height: 1-3.5 inches in 6 adjustments
- Starter: Recoil
- Transmission: Variable speed front wheel drive
- Blade Torque: 35-40 ft-lbs
Warranty
The Craftsman Walk Behind Mower 917.377820 comes with a 2-year limited warranty. This warranty covers any defects in materials and workmanship during non-commercial use. It includes coverage for both parts and labor on any repairs that fall within the warranty's specifications. To claim the warranty, one usually needs to present proof of purchase and contact the manufacturer or authorized service center. The specifics of how to claim may vary, so it's suggested to check the owner's manual or manufacturer's website for exact procedures.
