2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.378072
Background
The Craftsman 917.378072 is a walk-behind lawn mower designed for residential use. It is equipped with a Briggs & Stratton 12H802 2640-B1 engine, which offers a displacement of 159 cc and delivers 6.0 horsepower. The fuel system uses unleaded gasoline and has a fuel capacity of 1.6 quarts. The mower features a 22-inch steel blade, powered by the engine, which can be adjusted to nine different height positions ranging from 1-4 inches. This model also includes a side discharge mower deck and a removable mulching plug.
In terms of operation, the mower starts with a recoil mechanism, with the user pulling a starter cord while holding down the operator presence control bar. The control bar needs to be held down throughout the operation of the mower. The mower's handles can fold down for more compact storage. Routine maintenance includes checking and changing engine oil, cleaning the air filter, replacing the spark plug, sharpening the blade, and cleaning under the mower deck.
Technical Specifications
- Model Number: 917.378072
- Product Type: Walk Behind Mower
- Engine: Briggs & Stratton 12H802 2640-B1
- Displacement: 159 cc
- Power: 6.0 HP
- Fuel type: Unleaded gasoline
- Fuel capacity: 1.6 quarts
- Oil type: SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil capacity: 20 oz
- Blade: 22 in steel blade
- Blade bolt torque: 35-40 ft-lbs
- Wheel adjusters: 9 position height adjustment from 1-4 inches
- Weight: 70 lbs
Warranty
The Craftsman Walk Behind Mower 917.378072 comes with a 2-year limited warranty. This warranty covers defects in materials and workmanship from the date of purchase, as long as you have proof of purchase. It is important to note that this warranty does not cover any damage that may occur as a result of misuse or improper maintenance of the product. To claim the warranty, you will need to provide a copy of your proof of purchase. It is recommended to keep all purchase receipts in a safe place to avoid any potential problems when making a warranty claim.
