3 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.37807
Background
The Craftsman Walk Behind Mower Model 917.378070 is a gas-powered push lawn mower. It is equipped with a 6.0 horsepower Briggs & Stratton four-stroke engine. The engine has a 20 oz oil capacity and a 1.6 quart unleaded gasoline capacity. The mower features a 22 inch side discharge mowing deck that includes a removable mulching plug. The height can be adjusted to 9 positions from 1-4 inches with a single lever on each wheel. The mower also includes high rear wheels for improved traction.
The drive system of the mower is a front wheel drive system that is engaged via bail drive control and powers the wheels independently. The mower has a weight of 75 lbs and its dimensions are 21 inch width x 39 inch length x 40 inch height. It also features a folding T-shaped handle for storage purposes. Maintenance is simplified with the inclusion of a dust blocked engine cover and easily accessible filter.
Technical Specifications
- Model Number: 917.378070
- Product Type: Gas-powered push lawn mower
- Engine: 6.0 horsepower Briggs & Stratton four-stroke engine, Model 12H802
- Engine Oil Capacity: 20 oz
- Gasoline Capacity: 1.6 quart unleaded gasoline, minimum 87 octane rating recommended
- Cutting Deck: 22 inch side discharge mowing deck with removable mulching plug
- Height Adjustment: 9 position height adjustment from 1-4 inches
- Drive System: Front wheel drive system engaged via bail drive control
- Dimensions: 21 inch width x 39 inch length x 40 inch height
- Weight: 75 lbs
- Wheel Diameter: 16 inches
- Additional Features: Folding T-shaped handle for compact storage, dust blocked engine cover and easily accessible filter
Warranty
The Craftsman Walk Behind Mower Model 917.378070 comes with a two-year limited warranty. This warranty covers any defects in material or workmanship. However, it is important to note that the warranty is not valid for commercial use. To claim warranty, it is usually required to contact the manufacturer or the seller, provide proof of purchase, and describe the issue. It might also be necessary to ship or bring the product to a service center for inspection. Specific instructions for claiming the warranty should be detailed in the product's user manual or on the manufacturer's website.
