3 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.378361
Background
The Craftsman Walk Behind Mower 917.378361 is a walk-behind lawn mower that utilizes a 6.5 horsepower Briggs & Stratton engine. The cutting dimensions of this mower span 21 inches, with an adjustable cutting height that ranges from 1-1/4 to 3-3/4 inches, customizable across six different positions. The mower also possesses a 21 inch steel blade and a variable speed rear wheel drive.
The Craftsman 917.378361 is designed to be self-propelled and comes equipped with a steel mowing deck measuring 21 inches. The mower's cutting height can be easily adjusted between 1-1/4 to 3-3/4 inches using a single lever for each wheel. The mower is also capable of both mulching and bagging grass clippings, and includes a 2.4 bushel rear grass catcher. The rear-wheel drive system of the mower is controlled with a variable speed control, allowing for custom mowing speeds. The Briggs & Stratton 6.5 horsepower engine powers the mower and operates with a fuel capacity of 1.6 quarts of standard unleaded gasoline.
Technical Specifications
- Model Number: 917.378361
- Engine: 6.5 horsepower Briggs & Stratton engine, model 123K02-0267-E1
- Cutting Width: 21 inches
- Cutting Height: Adjusts from 1-1/4 to 3-3/4 inches in 6 adjustable positions
- Blade: 21 inch steel blade
- Drive: Variable speed rear wheel drive
- Fuel Capacity: 1.6 quarts of standard unleaded gasoline
- Engine Oil Capacity: 20 ounces
- Mowing Speed: Up to 3.2 mph
- Grass Handling: Can mulch or bag grass clippings, includes 2.4 bushel rear grass catcher
Warranty
The Craftsman Walk Behind Mower 917.378361 comes with a 2-year limited warranty, applicable for non-commercial use. This warranty is aimed at covering defects that arise from materials and workmanship. However, the warranty does not cover regular wear and tear, misuse, or issues stemming from lack of maintenance. Certain parts like the engine, belts, and blade have a shorter coverage period, specifically, these are covered only for a period of 90 days from the date of purchase. If a warranty claim is needed, it should be directed to the manufacturer, following their specific guidelines and processes, which usually involve providing proof of purchase and a detailed description of the defect.
