7 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.378493
Background
The Craftsman Walk Behind Mower 917.378493 is a gas-powered lawn mower, manufactured by the Roper Corporation for Sears under the Craftsman brand. It has a 6.75 hp Briggs & Stratton 125K02-0253-E1 engine, and a cutting width of 21 inches. The mower utilizes a 21-inch steel blade and operates at a blade speed of 3000 RPM. The cutting height of the mower can be adjusted between 1 and 3 inches.
The mower is equipped with several features. It has a variable speed rear wheel drive, allowing the self-propel speed to vary based on the drive control bar position. The lawn mower is mulching capable, eliminating the need for bags to collect grass clippings. It has a steel mowing deck with rear discharge. The mower utilizes a recoil starter, and the engine only runs when the operator control bar is held down. The front wheels of the mower are 7 inches in size, while the rear wheels are 8 inches. The mower runs on unleaded gasoline with a minimum octane level of 87 and can hold up to 1.6 quarts. The oil type is SAE 30 above 32°F and SAE 5W-30 below 32°F, with an oil capacity of 20 ounces.
Technical Specifications
- Model Number: 917.378493
- Product Type: Walk Behind Mower
- Engine: 6.75 hp Briggs & Stratton 125K02-0253-E1
- Cutting Width: 21 inches
- Cutting Height: 1-3 inches (adjustable)
- Drive Type: Variable speed rear wheel drive
- Blade: 21 inch steel blade
- Blade Speed: 3000 RPM
- Fuel Type: Unleaded gasoline, minimum 87 octane
- Fuel Capacity: 1.6 quarts
- Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil Capacity: 20 ounces
- Start Type: Recoil
- Mower Deck: Steel
- Front Wheel Size: 7 inches
- Rear Wheel Size: 8 inches
- Weight: 66 lbs
Warranty
The Craftsman Walk Behind Mower 917.378493 comes with a 2-year limited warranty. This warranty covers defects in materials and workmanship when the mower is used for residential purposes. Both parts and labor required for repairs within this period are covered under the warranty. Please note that the engine warranty is separately covered by Briggs & Stratton. To claim this warranty, you will likely need to provide proof of purchase and contact Craftsman or your retailer. The specific process may vary, so it's recommended to check with your seller or the Craftsman's official website for the exact procedures.
