6 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.37876
Background
The Craftsman Walk Behind Mower 917.378760 is a gas-powered mower designed for residential use. The mower is powered by a 6.25 HP Briggs & Stratton 123K02-0315-E1 engine and uses unleaded regular gasoline. It features a 21-inch cutting width and allows for adjustable cutting height between 1-3 inches. The model has a 21-inch hardened steel blade and utilizes a blade bolt torque of 35-40 ft-lbs. Its design includes 7-inch front wheels and 8-inch rear wheels.
The mower includes an operator presence control bar, a front wheel drive, and a 7-position height adjustment feature. Moreover, it has the capability for both mulching and rear bagging. The handle on the mower can be folded for easier storage. Starting the mower involves pushing the primer button three times if the engine is cold then pulling the starter cord while holding down the operator presence control bar. The cutting height can be adjusted by squeezing the height adjusters towards the wheels and moving them up or down. The mower has a weight of 70 lbs.
Technical Specifications
- Model Number: 917.378760
- Product Type: Walk Behind Mower
- Engine: 6.25 HP Briggs & Stratton 123K02-0315-E1
- Fuel Type: Unleaded Regular Gasoline, 0.6 Quarts Capacity
- Oil Type: SAE 30 Above 32°F, SAE 5W-30 Below 32°F, 20 oz Capacity
- Cutting Width: 21 Inches
- Cutting Height: 1-3 Inches Adjustable
- Blade: 21 Inch Hardened Steel
- Blade Bolt Torque: 35-40 ft-lbs
- Wheel Size: 7 Inches Front, 8 Inches Rear
- Weight: 70 lbs
- Additional Features: Operator Presence Control Bar, Front Wheel Drive, 7 Position Height Adjustment, Mulching and Rear Bagging Capability, Folding Handle for Storage
Warranty
The Craftsman Walk Behind Mower 917.378760 comes with a two-year limited warranty. This warranty coverage extends to any defects in material or workmanship. However, it must be noted that the warranty does not cover expendable parts of the mower. It also does not apply to any damage or issues arising from operator abuse or improper maintenance of the product. To claim the warranty, one would generally need to provide proof of purchase and contact the manufacturer or their authorized service providers, although the specific procedure may vary and should be confirmed with the manufacturer's customer service.
