6 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.37878
Background
The Craftsman Walk Behind Mower 917.378780 is a gas-powered lawn mower manufactured by the Roper Corporation for Sears. The engine of this mower is a 7.0 HP Briggs & Stratton 128602-0215-E1 4-cycle engine, which runs on unleaded regular gasoline. The fuel capacity is 1.6 quarts. Depending on the temperature, the engine uses either SAE 30 or SAE 5W-30 oil, with a capacity of 20 ounces. The mower is equipped with a 21-inch steel blade and has nine height adjustment positions ranging from 1.5 to 4 inches. It also has the capability for mulching and rear bagging.
The Craftsman 917.378780 is a self-propelled mower with a 21-inch cutting width. Its engine starts manually with a pull start. The mower deck is made of steel and allows for mulching or rear bagging of clippings. The height can be adjusted using the wheel adjusters on each wheel. The handle's height can also be adjusted. To operate the mower, the throttle control needs to be moved to the FAST position. The engine is primed three times if it's cold, and then the starter rope is pulled quickly. The blade will engage once the engine starts, as long as the operator presence control bar is held down. The drive can be engaged by pushing the drive control lever forward while continuing to hold down the operator presence control bar. The engine stops when the operator presence control bar is released.
Technical Specifications
- Model Number: 917.378780
- Product Type: Walk Behind Mower
- Engine: 7.0 HP Briggs & Stratton 128602-0215-E1 4-cycle engine
- Fuel type: Unleaded regular gasoline, 1.6 quart capacity
- Oil type: SAE 30 above 32°F, SAE 5W-30 below 32°F, 20 oz capacity
- Blade: 21" steel blade
- Blade bolt torque: 35-40 ft-lbs
- Wheel adjusters: 9 position height adjustment from 1-1/2" to 4"
- Mulching and rear bagging capability: Yes
- Start Method: Manual pull start
- Cutting Width: 21"
- Drive Type: Self-propelled
- Handle Height Adjustment: Yes
- Rear Clipping Deflector: Accessory available
- Operator Presence Control Bar: Yes
- Drive Control Lever: Yes
- Deck Material: Steel
Warranty
The Craftsman Walk Behind Mower 917.378780 comes with a 2-year limited warranty. This warranty is designed to cover any defects in materials and workmanship that may occur during normal use of the product. However, it's important to note that normal wear items such as blades, belts, and filters are not covered under this warranty. In the event that you encounter any issues covered by the warranty, you should contact Sears or Briggs & Stratton, which separately covers the engine warranty, to make a claim. Be prepared to provide details of the issue and proof of purchase.
