2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.3788
Background
The Craftsman Walk Behind Mower 917.378800 is a gas-powered push lawn mower, originally manufactured by Sears. It is equipped with a 5.5 horsepower Honda GCV160 4-stroke engine, providing the energy necessary to mow lawns. With a cutting width of 21 inches and a variable cutting height ranging from 1 inch to 3.75 inches across 9 adjustable positions, it allows for a fair degree of customization to suit a variety of lawn conditions. Further versatility is provided by its ability to switch between mulching, rear bagging, and side discharge operations.
This mower has a fuel tank capacity of 0.95 quarts and uses SAE 30 oil above 32°F, or SAE 5W-30 oil below 32°F, with an oil capacity of 18.5 oz. The mower works on a 21-inch steel blade, with a blade bolt torque of 35-40 ft-lbs. It has 7-inch front wheels and 8-inch rear wheels, providing mobility across the lawn. The rear wheels operate on a variable speed drive system, controlled by a walk-behind speed control mechanism. The mower also has an operator presence control bar and engine zone control cable, which stops the blades when the bar is released. Regular maintenance, such as oil changes, air filter inspections, and blade sharpening, is recommended.
Technical Specifications
- Model Number: 917.378800
- Product Type: Walk Behind Mower
- Engine: Honda GCV160, 160 cc, 5.5 HP, 4-stroke OHV
- Fuel Tank Capacity: 0.95 quarts
- Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil Capacity: 18.5 oz
- Blade: 21-inch steel blade
- Blade Bolt Torque: 35-40 ft-lbs
- Wheel Size: 7-inch front, 8-inch rear
- Cutting Width: 21 inches
- Cutting Height: 1-3.75 inches (9 positions)
- Drive: Variable speed rear wheel drive
- Grass Management: Converts between mulching, rear bagging, and side discharge modes
- Weight: 60 lbs
Warranty
The Craftsman Walk Behind Mower model 917.378800 comes with a 2-year limited warranty provided by Sears. This warranty covers any defects in materials or workmanship, including the mower deck, engine zone control cable, and the engine itself, provided it is maintained according to the operator's manual. However, the warranty does not extend to parts that are subject to normal wear and tear during use, such as belts, blades, and air filters. To claim this warranty, the owner likely needs to contact Sears' customer service or visit a Sears store, although specific instructions on how to claim the warranty were not provided in the document.
