5 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.378921
Background
The Craftsman Walk Behind Mower 917.378921 is a lawn mower produced by Roper Corp for Sears. It's a self-propelled, gas-powered unit with a Briggs & Stratton 4-cycle engine. This engine model is 125K02-0303-E1 and runs on regular unleaded gasoline with an octane rating of at least 87. The engine's oil capacity is 20 ounces and it requires different types of oil depending on the temperature, specifically SAE 30 oil for temperatures above 32°F and SAE 5W-30 for temperatures below 32°F.
The mower has a 21-inch steel deck for cutting grass. The cutting height can be adjusted between 1.5 to 4 inches using lever-activated wheel adjusters and the unit provides 9 different height positions. The mower also features a variable speed front-wheel drive system, which can reach speeds up to 3.2 mph. It's designed with a rear bagging feature and a side discharge function. The handle of the mower is foldable for convenient storage, and it can be adjusted to different height settings.
Technical Specifications
- Model Number: 917.378921
- Product Type: Walk Behind Mower
- Engine: 6.75 hp Briggs & Stratton 4-cycle engine, model 125K02-0303-E1. Uses regular unleaded gasoline with a minimum 87 octane rating. Oil capacity is 20 oz.
- Cutting Width: 21 inch steel mower deck
- Cutting Height: Adjusts from 1-1/2 to 4 inches in 9 height positions via lever activated wheel adjusters
- Drive System: Variable speed front wheel drive with speeds up to 3.2 mph
- Grass Handling: Rear bagging capability with optional grass catcher. Side discharge ability with mulching plug installed. Mulches clippings when setup without attachments.
- Handle: Upper handle folds for compact storage. Lower handle removes easily for very compact storage. Handles adjust to multiple height settings.
Warranty
The Craftsman Walk Behind Mower 917.378921 comes with a 2 year limited warranty provided by Sears. This warranty covers any defects in material or workmanship but does not include expendable parts such as blades and belts. To claim the warranty, customers should follow the appropriate procedures outlined in the manual or contact Sears directly.
