5 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.379203
Background
The Craftsman Walk Behind Mower model 917.379203 is a lawn mower designed to be pushed for operation. It is powered by a 6.25 horsepower Briggs & Stratton engine and utilizes rear wheel drive. The mower features seven different height adjustments, ranging from 1-1/4 to 3-3/4 inches, allowing for customization based on the user's lawn care needs.
The mower has a 22-inch blade and a cutting width of 21 inches. It runs on unleaded regular gasoline and uses SAE 30 oil above 32°F, and SAE 5W-30 below 32°F. The lawn mower has 7-inch front wheels and 8-inch rear wheels, and weighs 75 lbs. Additionally, the mower deck is made of steel and has a removable mulching plug for side discharge or mulching modes. The handle of the mower is adjustable in height and can fold for compact storage. The mower also includes features such as a removable grass bagger, rear wheel height adjusters, and a system to prevent accidental starting. It also allows easy access to oil and the bottom blade for cleaning and blade removal.
Technical Specifications
- Model Number: 917.379203
- Product Type: Walk Behind Mower
- Engine: Briggs & Stratton 6.25 HP
- Displacement: 190cc
- Fuel Capacity: 1.6 quarts unleaded regular gasoline (87 octane min)
- Oil Capacity: 20 oz
- Oil Type: API SG-SL
- Blade Length: 22"
- Cutting Width: 21"
- Cutting Height: 7-position height adjustment from 1-1/4 to 3-3/4 inches
- Wheels: 7" plastic front, 8" plastic rear
- Weight: 75 lbs
- Deck Material: Steel with removable mulching plug
- Handle: 2-point height adjustment, foldable for storage
- Starter: Manual recoil
- Speed: Variable, 0-3.1 mph forward
- Standard Features: Removable grass bagger, rear wheel height adjusters, zone start safety system
- Maintenance Features: Easy oil access, bottom blade access for cleaning and blade removal.
Warranty
The Craftsman Walk Behind Mower model 917.379203 comes with a 2-year limited warranty. This warranty coverage ensures the mower is protected against any manufacturing defects or issues that may arise under normal use conditions. To claim the warranty, users will typically need to contact the manufacturer or the retail store where the product was purchased, supplying necessary details such as proof of purchase, model number, and a description of the issue. It is crucial to note that regular maintenance, including changing the engine oil every 25 hours of use and cleaning or replacing the foam air filter annually, is recommended to maintain the mower's optimal performance and may be necessary to uphold the warranty.
