1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.38052
Background
The Craftsman Walk Behind Mower 917.380520 is a lawn mower with a side discharge rotary. It utilizes a 5.0 horsepower 4-cycle gas engine and is suitable for residential lawn cutting. The mower has a 22-inch width for cutting, and the height for cutting can be adjusted between 1 and 3 inches. The fuel capacity is 1.5 quarts of unleaded regular gasoline, and the oil capacity is 20 oz, using API SG grade detergent oil.
The mower also features a throttle control for adjusting the engine speed and is equipped with a recoil start. It has an operator presence control bar, starter handle, and engine speed control lever situated on the upper handle for convenience. The product also has optional features like a mulching kit and a rear grass catcher, which can be used for mulching clippings or bagging.
Technical Specifications
- Engine: 5.0 hp 4-cycle gas engine
- Engine Model: 143.945004
- Displacement: 11.5 cu in
- Fuel Capacity: 1.5 quarts unleaded regular gasoline
- Oil Capacity: 20 oz
- Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F, API SG grade detergent oil
- Spark Plug: Champion RJ19LM, gap 0.030 in
- Valve Clearance (Intake/Exhaust): 0.008 in
- Air Gap: 0.125 in
- Blade Bolt Torque: 35-40 ft-lbs
- Cutting Width: 22 in
- Cutting Height: Adjustable between 1-3 in
- Mulching Capable: Yes, with optional mulching kit
- Rear Bag Capable: Yes, with optional 2.5 bushel catcher
- Throttle Control: Yes, for adjusting engine speed between low and high
- Start Type: Recoil start
Warranty
The Craftsman Walk Behind Mower 917.380520 comes with a two-year limited warranty. This warranty covers defects in materials and workmanship under non-commercial use scenarios. It includes parts such as belts and blades, however, normal wear items are not covered under the warranty. There's a specific limitation on the engine warranty, which is two years for non-commercial use and 90 days for commercial or rental use. To claim this warranty, it is recommended to use the guide provided in the owner's manual or contact the manufacturer directly. Please note that it's essential to keep a record of your purchase to facilitate the warranty claim process.
