2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
917.38279
Background
The Craftsman Walk Behind Mower 917.38279 is a gas-powered lawn mower that was introduced to the market in 2010. Manufactured by Roper Corp for Sears under the Craftsman brand, the mower employs a 159 cc Craftsman engine which uses gasoline as fuel to deliver 5.5 ft-lbs gross torque. It is a push lawn mower with variable speed rear wheel drive. The cutting width of the mower is 21 inches with a cutting height that varies between 1 and 3.75 inches across seven positions. The mower deck is made of steel and is started by a recoil pull start. The product weighs 66 lbs.
The Craftsman Walk Behind Mower 917.38279 comes with several features that enhance its functionality. The self-propelled rear wheel drive system with adjustable speed control allows the operator to match their walking pace for a more manageable mowing experience. The wide cutting path provided by the 21" steel deck aids in reducing mowing time. The 159cc Craftsman OHV engine, with an automatic choke system, facilitates powerful performance and smooth start-ups. The mower also incorporates a dual-lever, six-position height adjustment, allowing for easy adaptation of cutting height from 1 to 3.75 inches. Additional features include an adjustable ergonomic handle, large 8 inch rear wheels, and 13 x 5 inch front wheels. For convenience, the mower can be folded up for compact storage.
Technical Specifications
- Model Number: 917.38279
- Product Type: Walk Behind Mower
- Engine: 159 cc
- Power: 5.5 ft-lbs gross torque
- Fuel Type: Gasoline
- Cutting Width: 21 inches
- Cutting Height: 1-3.75 inches (7 positions)
- Drive: Push, variable speed rear wheel drive
- Deck Material: Steel
- Start Method: Recoil pull start
- Weight: 66 lbs
- Handle: Adjustable ergonomic handle
- Rear Wheel Size: 8 inches
- Front Wheel Size: 13 x 5 inches
- Storage: Folds up for compact storage
Warranty
The Craftsman Walk Behind Mower 917.38279 comes with a limited warranty that lasts for 2 years. This warranty covers any defects in both materials and workmanship when used non-commercially. To claim the warranty, one must provide proof of purchase along with maintenance records. It is important to note that the warranty for the engine may have different terms and conditions.
