5 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.387242
Background
The Craftsman Walk Behind Mower 917.387242 is a gas-powered lawn mower produced by the Roper Corporation for Sears. This machine is designed to assist in maintaining and trimming green spaces, with a particular focus on residential lawns. The mower is equipped with a 6.0 horsepower Craftsman 4-cycle engine and has a 22-inch steel cutting deck. It employs a rotary blade system for cutting grass, and operates on unleaded regular gasoline.
The mower incorporates a number of features designed to enhance its performance and usability. It has a variable speed rear-wheel drive for easier maneuverability, and an electric start system for convenience. The mower also offers mulching capability and is capable of rear bagging, with the use of a removable mulching plug and optional grass collection bag. Furthermore, it offers nine cutting height positions, ranging from 1 to 4 inches, which can be adjusted to suit the specific conditions of the lawn being maintained.
Technical Specifications
- Model Number: 917.387242
- Product Type: Walk Behind Mower
- Engine: 6.0 horsepower 4-cycle
- Displacement: 11.5 cu. in.
- Fuel type: Unleaded regular gasoline, 1.5 quarts capacity
- Oil type: SAE 30 above 32°F, SAE 5W-30 below 32°F, 20 oz capacity
- Spark plug: Champion RJ19LM or J19LM, gap .030 in.
- Valve clearance (intake and exhaust): .004 -.008 in.
- Solid state ignition air gap: .0125 in.
- Blade bolt torque: 35-40 ft-lbs
- Cutting width: 22 in.
- Cutting height positions: 9 positions from 1-4 inches
- Start method: Electric start
- Grass handling: Mulching and rear bagging capability
- Drive type: Rear-wheel drive, variable speed
Warranty
The Craftsman Walk Behind Mower 917.387242 comes with a 2-year limited warranty. This warranty covers any defects in material or workmanship when the mower is used for residential purposes and is maintained as per the guidelines mentioned in the owner's manual. It's important to note that the warranty does not cover normal wear parts or any damage that is caused due to improper use or maintenance. To claim the warranty, refer to the owner's manual or contact the manufacturer's customer service. The warranty claim will require proof of purchase, so it's advisable to keep your sales receipt or any other purchase documents.
