5 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.387302
Background
The Craftsman Walk Behind Mower 917.387302 is a gas-powered lawn mower, designed to be manually pushed. It is equipped with a Craftsman 143.996004 6.0 HP engine and has an engine displacement of 11.5 cu. in. The mower operates on regular unleaded gasoline with a fuel capacity of 1.5 quarts. The mower utilizes SAE 30 oil type above 32°F and SAE 5W-30 below 32°F with an oil capacity of 20 oz. It uses a solid state electronic ignition system and a torque for the blade bolt falls within 35-40 ft. lbs. The mower has a replaceable paper cartridge for the air filter.
The mower has a cutting width of 22 inches, and the cutting height can be adjusted between 1 to 3.5 inches in seven different positions. It includes a rear bagging system with a grass catcher of 2.4 bushel capacity. The mower is designed for user convenience with adjustable handles. To start and operate the mower, an operator presence control bar must be held down. The mower comes with a recoil rope start and fixed speed throttle control. Regular maintenance of the mower includes changing the engine oil, replacing the air filter and spark plug, and sharpening the blade as needed. Proper storage between seasons is also necessary to ensure the mower's longevity. This model is suitable for small to medium-sized yards, allowing for a traditional mowing experience with adjustable cutting heights and rear bagging capability.
Technical Specifications
- Model Number: 917.387302
- Engine: 6.0 HP
- Displacement: 11.5 cu. in.
- Fuel Type: Unleaded regular gasoline
- Fuel Capacity: 1.5 quarts
- Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil Capacity: 20 oz.
- Ignition: Solid state electronic ignition
- Blade Bolt Torque: 35-40 ft. lbs.
- Air Filter: Replaceable paper cartridge
- Cutting Width: 22 in.
- Cutting Height: 1-3.5 in, 7 position adjustment
- Grass Catcher: 2.4 bushel capacity, rear bagging
Warranty
The Craftsman Walk Behind Mower 917.387302 comes with a 2-year limited warranty. This warranty coverage includes the protection against any defects in materials or workmanship for the specified period. To claim the warranty, the owner of the mower should have proof of purchase, and if any malfunction or defect arises, they should contact the manufacturer or the authorized dealer from where the product was purchased. It's important to note that the warranty may not cover normal wear and tear, or any damage resulting from misuse or improper maintenance of the product. Therefore, the owner is encouraged to follow the operation and maintenance guidelines provided by the manufacturer to ensure the longevity of the mower.
