1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.38743
Background
The Craftsman Walk Behind Mower 917.387430 is a lawn care tool with a 22-inch rotary mechanism for cutting grass. Manufactured by Roper Corp for Sears under the Craftsman brand, it features a side discharge system, which expels cut grass from the side of the unit.
The mower is powered by a 6.0 horsepower Briggs & Stratton 143.12HS02-2682-B1 4-cycle engine. It has a fuel capacity of 1.5 quarts of unleaded regular gasoline, and an oil capacity of 20 oz of either SAE 30 oil or SAE 5W-30, depending on the temperature. The cutting height is adjustable, ranging from 1 to 3 5/8 inches across seven positions. It operates through a manual start with a recoil starter, and the engine speed can be controlled via a throttle. It also has a foldable handle for more compact storage. Regular inspection and replacement of the air filter, engine oil, and blade are needed for proper maintenance. The mower is primarily designed for residential use, capable of cutting grass up to 10 inches tall.
Technical Specifications
- Model Number: 917.387430
- Product Type: Walk Behind Mower
- Cutting Width: 22 inches with side discharge
- Engine Type: 6.0 horsepower 4-cycle engine
- Fuel Capacity: 1.5 quarts unleaded regular gasoline, min 87 octane
- Oil Capacity: 20 oz SAE 30 oil above 32°F, SAE 5W-30 below 32°F
- Ignition Type: Solid state ignition with .0125 in air gap
- Blade Torque: 35-40 ft-lbs
- Cutting Height: Adjustable from 1-3 5/8 inches in 7 positions
- Start Type: Manual start with recoil starter
- Throttle Control: Available for engine speed
- Handle: Folding handle for storage
- Usage: Designed for residential use to cut grass up to 10 inches tall.
Warranty
The Craftsman Walk Behind Mower 917.387430 comes with a 2-year limited warranty that covers defects in materials and workmanship for non-commercial use. However, please note that this warranty does not cover expendable parts such as belts, blades, air filters, etc. For those using the mower for commercial or rental purposes, the warranty period is reduced to 90 days. To claim the warranty, you should follow the instructions provided in the owner's manual. Ensure you have the necessary purchase documents ready when initiating the warranty claim process.
