5 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.38746
Background
The Craftsman Walk Behind Mower 917.387460, manufactured by Roper Corp for Sears, is a gas-powered lawn mower. This mower is equipped with a 4.5 horsepower engine, providing adequate power to handle most residential lawn mowing tasks. The cutting width of this model is 22 inches, and it has the capability to adjust the cutting height from 1 to 3.5 inches in 6 increments.
The mower operates with a 22 inch steel blade and features variable speed rear wheel drive that is push propelled. Starting the mower is accomplished through recoil start. It provides three options for handling grass clippings, offering rear bagging, mulching or side discharge. The mower has a displacement of 140cc, a fuel capacity of 1.5 quarts of unleaded gasoline, and an oil capacity of 20 oz SAE 30 oil. It is designed for residential yard cutting.
Technical Specifications
- Model Number: 917.387460
- Engine: 4.5 horsepower, 4-cycle OHV
- Engine Model: 143.044500
- Displacement: 140cc
- Fuel Capacity: 1.5 quarts unleaded gasoline
- Oil Capacity: 20 oz SAE 30 oil
- Cutting Width: 22 inches
- Cutting Height: 1-3.5 inches adjustable in 6 increments
- Blade: 22 inch steel
- Drive: Push propelled, variable speed rear wheel drive
- Start: Recoil start
- Clippings Disposal: Rear bagging, mulching, or side discharge
- Blade Bolt Torque: 35-40 ft-lbs
- Spark Plug: Champion RJ19LM (gap: .030")
Warranty
The Craftsman Walk Behind Mower 917.387460 comes with a 2-year limited warranty. This warranty covers any defects in the materials and workmanship of the mower for non-commercial use. However, it's important to note that normal wear parts like belts, blades, and filters are not covered under this warranty. In order to claim the warranty, one should follow the guidelines provided in the product's manual or contact the manufacturer directly. It may typically require providing proof of purchase and details about the nature of the defect or issue with the product.
