1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.3875
Background
The Craftsman Walk Behind Mower 917.387500, manufactured by Roper Corp for Sears, is a gas-powered lawn mower designed for residential use. It is equipped with features that are designed to facilitate lawn care. The mower operates with a gasoline capacity of 1.5 quarts using unleaded regular gasoline with an octane minimum of 87. Its oil type is SAE 30 above 32°F and SAE 5W-30 below 32°F, with an oil capacity of 20 fluid ounces.
The mower's operational design includes a primer button for starting a cold engine and an operator presence control bar for safe operation. The cutting height of the machine can be adjusted from 1 to 3.5 inches in 7/8 inch increments by moving the height adjustment levers on each wheel. Maintenance of the Craftsman Walk Behind Mower 917.387500 involves regular checks of engine oil, change of oil after the initial 5-8 hours of operation, annual replacement of the spark plug, and cleaning of the air filter and the underside of the mower after each use.
Technical Specifications
- Model Number: 917.387500
- Product Type: Walk Behind Mower
- Manufacturer: Sears, Roebuck and Co.
- Fuel Type: Gasoline
- Gasoline Capacity: 1.5 quarts, Unleaded Regular (87 octane minimum)
- Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil Capacity: 20 fluid ounces
- Spark Plug: Champion RJ19LM or J19LM (gap .030 inches)
- Blade Bolt Torque: 35-40 ft-lbs
- Operation: Manual pull start, fixed engine speed
- Safety Feature: Operator presence control bar
- Cutting Height: Adjustable from 1-3.5 inches in 7/8 inch increments
- Handle Height: Adjustable
Warranty
The Craftsman Walk Behind Mower 917.387500 comes with a two-year limited warranty. This warranty covers defects in material or workmanship but excludes expendable parts like belts, blades, and air filters that can wear out due to normal use. If the mower is used for commercial purposes, the coverage is only for 90 days from the date of purchase. It's important to note that the warranty may become void if the mower is abused, neglected, or not properly maintained. To claim the warranty, you would need to contact Sears or visit one of their parts centers with your proof of purchase. It's recommended to use manufacturer-approved parts for maintenance and repairs to uphold the warranty coverage.
