1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.387611
Background
The Craftsman Walk Behind Mower 917.387611 is a rotary push mower that is designed to cut grass in residential lawns. It has a 22-inch side discharge and is powered by a 143.024208 4-cycle engine. The fuel capacity for this engine is 1.5 quarts and operates on unleaded gasoline. In terms of the oil, it uses SAE 30 when the temperature is above 32°F and SAE 5W-30 when it's below 32°F, with a capacity of 20 oz. The mower's cutting width is 22 inches and the cutting height can be adjusted between 1-1/2 - 4 inches depending on the user's preference.
This lawn mower is equipped with multiple features to enhance its functionality. It offers the possibility of mulching, bagging or side discharging the cut grass. The height can be adjusted to 9 different positions ranging from 1-1/2 - 4 inches. It has a folding handle for compact storage and a zone control safety system. The mower has 7-inch front wheels and 8-inch rear wheels. It weighs approximately 60 lbs. Regular maintenance is necessary for the longevity of the mower, including checking the engine oil before each use, changing the engine oil after the first 5-8 hours of use then every 25 hours, cleaning the air filter every 25 hours, replacing it yearly, replacing the spark plug yearly, and sharpening or replacing the blade yearly.
Technical Specifications
- Model Number: 917.387611
- Product: Craftsman Walk Behind Mower 917.387611
- Product Type: Walk Behind Mower
- Manufacturer: Sears, Roebuck and Co.
- Engine: 143.024208 4-cycle engine
- Cutting Width: 22 in
- Blade: 22 in mulching or discharging blade
- Fuel Type: Unleaded gasoline
- Fuel Capacity: 1.5 quart
- Oil Type: SAE 30 (above 32°F); SAE 5W-30 (below 32°F)
- Oil Capacity: 20 oz
- Cutting Height: 1-1/2 - 4 in (9 position)
- Wheels: 7 in front wheels, 8 in rear wheels
- Weight: 60 lbs
Warranty
The Craftsman Walk Behind Mower model 917.387611 comes with a 2-year limited warranty provided by Sears. This warranty does not cover normal wear parts such as belts or blades. Additionally, the warranty is voided if the mower is utilized for commercial purposes. To claim the warranty, contact the Sears service network.
