5 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.38766
Background
The Craftsman Walk Behind Mower 917.387660 is a lawn mower, which is gas-powered and operated by pushing it manually. The product features a 22-inch side discharge deck, allowing for a considerable cutting range during use. It is powered by a 4.5 horsepower Craftsman engine, model 143.044500 or 143.044510, with a displacement of 223cc. The fuel capacity is 1.5 quarts of unleaded gasoline, with a minimum octane level of 87. The oil type changes depending on temperature, with SAE 30 being used above 32°F and SAE 5W-30 being used below 32°F. The oil capacity is 20 oz.
In addition to these specifications, the mower has several features to enhance its functionality. These include the ability to mulch clippings with a plug, a control bar for operation, and height adjustment levers for managing cutting height. The handle is T-shaped and can fold for compact storage. For usage, the mower is primarily meant for residential lawn care. The side discharge design pushes clippings out from the right side during mowing, while the mulcher plug allows for the option of mulching clippings. The cutting height can be adjusted between 1 and 3.75 inches, depending on the type and height of the grass in the lawn. The mower is operated by adding fuel and oil as per the user manual, starting the engine with a pull of the starter rope, and pushing the mower while holding the control bar. To stop the blade, the control bar is released.
Technical Specifications
- Engine: 4.5 hp Craftsman 4-cycle engine, model 143.044500 or 143.044510
- Displacement: 223cc
- Fuel Capacity: 1.5 quarts unleaded gasoline (87 octane minimum)
- Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil Capacity: 20 oz
- Deck Width: 22 inches
- Cutting Height: Adjustable between 1-3.75 inches (9 positions)
- Starting Mechanism: Recoil start
- Transmission: Manual push
- Wheel Size:
- Front: 7 inches
- Rear: 8 inches
- Weight: 70 lbs
Warranty
The Craftsman Walk Behind Mower 917.387660 comes with a 2 year limited warranty. This warranty covers defects in materials and workmanship, which means that if the product fails due to a manufacturing defect, the company will repair or replace it free of charge. However, this warranty does not cover normal wear items such as oil, spark plugs, air filters, and blades. It's important to note that the mower must be maintained according to the instructions provided in the owner's manual to receive full warranty coverage. For commercial or rental use, the warranty is reduced to only 90 days from the date of purchase.
