Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.387681
Background
The Craftsman Walk Behind Mower 917.387681 is a gas-operated rotary lawnmower. It is designed with a 22-inch side discharge deck and is powered by a 6.5 horsepower Briggs and Stratton engine. The mower also features a nine-position height adjustment capability which ranges from 1.5 to 4 inches. Additional features include a control bar for the operator's presence, a folding handle for storage, 12-inch rear wheels, and 7-inch front wheels.
In terms of specifications, the Craftsman Walk Behind Mower utilizes a Briggs and Stratton engine with a displacement of 163 cc. The fuel tank has a capacity of 1.6 quarts and uses unleaded regular gasoline with a minimum octane of 87. The oil type varies depending on the temperature, with SAE 30 being used above 32°F and SAE 5W-30 below 32°F. The oil capacity is 20 oz. The blade bolt has a torque of 35-40 ft-lbs, and the spark plug is a Champion RJ19LM with a gap of .030". The weight of the mower is approximately 150 lbs.
Technical Specifications
- Model Number: 917.387681
- Product Type: Walk Behind Mower
- Engine: 6.5 HP Briggs & Stratton
- Displacement: 163 cc
- Cutting Width: 22"
- Height Adjustment: 9 positions, 1.5" to 4"
- Operator Presence Control Bar: Yes
- Folding Handle: Yes
- Rear Wheel Size: 12"
- Front Wheel Size: 7"
- Fuel Tank Capacity: 1.6 quarts
- Fuel Type: Unleaded regular gasoline, 87 octane minimum
- Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil Capacity: 20 oz
- Blade Bolt Torque: 35-40 ft-lbs
- Spark Plug: Champion RJ19LM, gap .030"
- Weight: Approx. 150 lbs
Warranty
The Craftsman Walk Behind Mower 917.387681 comes with a 2-year limited warranty. This warranty covers any defects in materials or workmanship for residential use. However, it should be noted that this warranty does not cover normal wear and tear, or any damage resulting from improper use or abuse of the mower. To claim the warranty, it is typically required to provide proof of purchase and contact the manufacturer or authorized service center, although the exact process may vary and should be confirmed by referring to the owner's manual or direct contact with the manufacturer.
