5 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.388224
Background
The Craftsman Walk Behind Mower 917.388224 is a gas-powered lawn mower produced by Sears. It's equipped with a Craftsman branded engine, model 143.014504, which is a 4-cycle engine with a displacement of 140 cc and a power output of 4.5 HP. The ignition system includes a solid state with a resistor spark plug. The fuel capacity of this mower is 1.5 quarts of unleaded gasoline.
This mower has a 22-inch cutting width with a steel mulching blade. The cutting height is adjustable and can be set between 1-3/4 to 4 inches in 7 different positions. In terms of drivetrain, it is a manual push drive mower with front ball bearing wheels. The mower measures 57 inches in length, 23 inches in width and 40 inches in height, and it weighs 70 pounds. For maintenance, the air filter should be cleaned every 25 hours or annually, and an oil change is required after the first 5-8 hours of operation and every 25 hours thereafter.
Technical Specifications
- Model Number: 917.388224
- Product Type: Gas-Powered Rotary Lawn Mower
- Engine: 4-cycle, 140 cc, 4.5 HP, with solid state ignition and resistor spark plug
- Fuel Capacity: 1.5 quarts of unleaded gasoline
- Cutting Deck: 22 inch, with adjustable cutting height from 1-3/4 to 4 inches in 7 positions
- Drive Type: Manual push with front ball bearing wheels
- Dimensions: 57 inches in length, 23 inches in width, 40 inches in height
- Weight: 70 pounds
Warranty
The Craftsman Walk Behind Mower 917.388224 comes with a 2-year limited warranty. This warranty covers any defects in both materials and workmanship, provided that the mower is utilized for residential purposes under normal use and maintenance conditions. In order to claim the warranty, one would typically need to contact the manufacturer, in this case, Sears, with proof of purchase and details about the defect. The specific claim process may vary, hence, it is advisable to consult the warranty section of the product manual or the manufacturer's website for detailed instructions.
