1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
917.38837
Background
The Craftsman Walk Behind Mower 917.388370 is a lawn mower designed for home use. Produced by Roper Corp for Sears under the Craftsman Brand, the mower is gas-powered and self-propelled. It comes equipped with a 22" cutting deck and a 163cc Briggs & Stratton 675 Series engine, which provides the necessary power to mow lawns of different sizes. The automatic choke and ready start of the engine allow for uncomplicated operation of the mower.
The product has a variety of features intended to facilitate lawn maintenance. For instance, its variable front wheel drive can accommodate uneven terrain, and its 7 height adjustments (from 1.25” to 3.75”) can handle different grass lengths and conditions. The mower deck, made of stamped steel, can either discharge grass clippings from the side or mulch them, depending on the user's preference. The mower also includes an easy pull recoil starter for hassle-free start-up.
Technical Specifications
- Model Number: 917.388370
- Product Type: Walk Behind Mower
- Engine: 163cc Briggs & Stratton 675 Series
- Power: 5.5 ft-lbs gross torque
- Fuel Capacity: 0.9 quarts
- Deck Size: 22”
- Cutting Height: 1.25” to 3.75”
- Drive: Variable front wheel drive
- Weight: 70 lbs
- Cutting Deck Material: Stamped Steel
- Finish: Rust-resistant powder coat
- Handle: Loop style
- Starting Method: Easy pull recoil starter
Warranty
The Craftsman Walk Behind Mower 917.388370 comes with a 2 year limited warranty. This warranty covers defects in materials and workmanship, ensuring your product is free from any inherent faults. However, it's important to note that the engine warranty is covered separately by Briggs & Stratton. To claim the warranty, you would need to present a proof of purchase and demonstrate that the product has been used under normal residential conditions.
