1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.3883
Background
The Craftsman Walk Behind Mower 917.388300 is a piece of gardening equipment produced by Sears. This mower is categorized as a 21-inch multi-cut rotary lawn mower. Its primary use lies in residential yard maintenance. The product brings together several features that aid in this function.
One of its key features is a 6.0 horsepower Briggs & Stratton engine with a recoil start. It also includes a 7-position height adjustment feature that ranges from 1-1/4 to 4 inches. This offers flexibility in determining the height of the cut grass. The mower has the capability for rear bagging, mulching, and side discharge. Its 21" steel deck enables the blades to cut a full 21" path in one pass, reducing the amount of passes required. Dual point height adjusters simplify the process of altering the cutting height. The mower also comes equipped with an operator presence control bar, which needs to be held down to the handle in order to start and operate the mower.
Technical Specifications
- Model Number: 917.388300
- Product Type: Walk Behind Mower
- Horsepower: 6.0 hp
- Gasoline Capacity/Type: 1.5 quarts unleaded regular
- Oil Type: SAE 30 (above 32°F), SAE 5W-30 (below 32°F)
- Oil Capacity: 20 oz
- Spark Plug: Champion RJ19LM or J19LM (Gap: .030")
- Valve Clearance - Intake: .004 - .008 inches
- Valve Clearance - Exhaust: .004 - .008 inches
- Solid State Ignition Air Gap: .0125 inches
- Blade Bolt Torque: 35-40 ft-lbs
- Cutting Width: 21 inches
- Cutting Height Adjustment: 7 positions, 1-1/4 to 4 inches
- Grass Processing: Rear bagging, mulching, side discharge
- Operator Presence Control: Yes
Warranty
The Craftsman Walk Behind Mower 917.388300 comes with a limited warranty that lasts for 2 years, which covers defects in material and workmanship, but only for non-commercial usage. The warranty coverage is reduced to 90 days for commercial or rental usage. It's important to note that expendable parts such as belts, blades, and air filters are not included in this warranty. The engine has a separate warranty provided by the engine manufacturer. To claim the warranty, you should contact the manufacturer or the retailer where the product was purchased, ensuring to provide details such as the model number, date of purchase, and a description of the issue.
