1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.388521
Background
The Craftsman Walk Behind Mower 917.388521 is a lawn mower with a 21-inch rear discharge rotary blade. It is powered by a 6.5 horsepower Briggs & Stratton engine. The mower is designed to be used in residential settings for the purpose of maintaining lawns. It offers the flexibility of either bagging cut grass or mulching it.
The mower has a Briggs & Stratton engine with a displacement of 123cc and a fuel tank capacity of 1.6 quarts. It runs on unleaded regular gasoline with a minimum of 87 octanes. The mower uses SAE 30 oil when the temperature is above 32°F and SAE 5W-30 oil when the temperature is below 32°F. The oil capacity is 20 ounces. The cutting width is 21 inches, and the height of the cut can be adjusted between 1 to 3 inches. The mower blade operates at a speed of 3000 RPM. It has a rear bag with a capacity of 2.5 bushels and weighs 60 lbs. The mower comes with a Briggs & Stratton OHV engine, 21" steel mower deck, 9 position height adjustment lever, rear bag grass catcher, mulching capability, and a folding T-shaped handle.
Technical Specifications
- Model Number: 917.388521
- Product Type: Walk Behind Mower
- Engine: Briggs & Stratton 6.5 HP
- Displacement: 123cc
- Fuel tank capacity: 1.6 quarts
- Fuel type: Unleaded regular gasoline, 87 octane minimum
- Oil type: SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil capacity: 20 ounces
- Cutting width: 21 inches
- Cutting height: 1-3 inches adjustable
- Blade speed: 3000 RPM
- Rear bag capacity: 2.5 bushels
- Weight: 60 lbs
Warranty
The Craftsman Walk Behind Mower 917.388521 comes with a limited warranty that lasts for 2 years for residential use. If the product is used for commercial or rental purposes, the warranty coverage is for 90 days from the original date of purchase. This warranty covers any defects that may arise due to faulty materials or workmanship, provided that the mower is used for its intended purpose. It is important to note that the warranty does not cover normal wear parts or damage that occurs due to improper use or lack of proper maintenance.
