5 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.388632
Background
The Craftsman Walk Behind Mower 917.388632 is a lawn mower produced by Sears, Roebuck and Co. It is characterized by a 4.5 horsepower Tecumseh 4-cycle engine and a steel deck. The 21-inch steel blade and adjustable front wheels enable it to cut grass at varying heights between 1-3 inches. The rear discharge feature allows for the ejection of grass clippings, which can also be collected using an optional nylon mesh grass catcher bag. The mower is gas-powered, requiring unleaded gasoline. It also utilizes oil, with varying types recommended depending on the temperature.
This walk behind mower is designed for residential yard maintenance. Its features allow for customization and adaptability in lawn care. The presence of an operator control bar ensures the blade stops when released. The mower also includes adjustable ball bearing front wheels and 7-inch plastic rear wheels. The weight of the machine is 60 lbs and it is push propelled with variable speed. Regular maintenance, as indicated in the owner's manual, can help ensure longevity and optimal performance.
Technical Specifications
- Model Number: 917.388632
- Product Type: Walk Behind Mower
- Engine: 4.5 horsepower Tecumseh 4-cycle engine, model 143.044500
- Cutting Width: 21 inches
- Cutting Height: Adjustable between 1-3 inches in 6 height positions
- Discharge: Rear discharge
- Start Type: Recoil start
- Transmission: Push propelled, variable speed
- Blade: 21 inch steel blade
- Deck: Steel
- Weight: 60 lbs
- Fuel Type: Unleaded gasoline, 1.5 quarts capacity
- Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F, 20 oz capacity
- Rear Wheels: 7 inch plastic wheels
- Front Wheels: Adjustable ball bearing wheels
- Grass Catcher: 2.5 bushel nylon mesh bag
Warranty
The Craftsman Walk Behind Mower 917.388632 comes with a limited warranty that lasts for 2 years. This warranty covers any defects in materials and workmanship for non-commercial use. Under this warranty, any defect in material or workmanship will be repaired free of charge. However, it's important to note that the warranty does not include normal wear parts such as blades, belts, air filters, and spark plugs. The engine warranty is also provided for a duration of 2 years.
