1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.38874
Background
The Craftsman Walk Behind Mower 917.388740 is a lawn mower designed for residential use. It is characterized by a rear discharge rotary system and is outfitted with a Briggs & Stratton 123K02-0181-E1 engine that delivers an output of 5 horsepower. This model is notable for its 21-inch cutting width, which allows for efficient coverage of medium to large lawns.
In terms of operation, the mower is started by pushing the primer bulb three times and pulling the starter rope while the operator presence control bar is held down. A unique feature of this model is its mulching blade, which recuts grass clippings and disperses them back into the lawn. This eliminates the need for bagging and provides a natural fertilizer for the grass. The cutting height can be adjusted using the wheel height adjusters. Maintenance tasks such as changing the engine oil, replacing the air filter, spark plug, and blade, and cleaning the mower housing are outlined in the owner's manual.
Technical Specifications
- Model Number: 917.388740
- Product Type: Walk Behind Mower
- Engine: Briggs & Stratton 123K02-0181-E1, 5 HP
- Fuel capacity: 1.6 quarts unleaded regular gasoline
- Oil capacity: 20 oz.
- Blade bolt torque: 35-40 ft-lbs
- Cutting Width: 21 inches
- Cutting heights: 1-3.5 inches
- Wheel size: 7 inches front, 8 inches rear
- Weight: 70 lbs
Warranty
The Craftsman Walk Behind Mower 917.388740 comes with a limited two-year warranty for residential use, covering any defects in materials and workmanship. If the mower is used commercially, the warranty period is limited to 90 days from the date of purchase. The warranty does not extend to normal wear items such as blades, belts, air filters, and spark plugs. Damage caused by operator abuse or negligence, such as a bent crankshaft, is also not covered under the warranty. To claim the warranty, contact the Sears customer service or visit a Sears store with your proof of purchase.
