1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.38893
Background
The Craftsman Walk Behind Mower 917.388930 is a lawn mower that is manually pushed for operation. It is designed with a 21" rotary cutting deck, which is constructed from rust-resistant steel. The deck is equipped with a rear discharge system and has the ability to adjust its height between 1-1/4" to 3-3/4" in nine different settings.
The mower is powered by a 6.0 horsepower Briggs & Stratton 4-cycle engine, model 122K02-0577-E1. The engine has an overhead valve design and uses a recoil start mechanism. It has a fuel capacity of 1.6 quarts and operates on regular unleaded gasoline. The mower is designed with 8" front wheels and 12" rear wheels. The dimensions of the mower are 43" x 21" x 38" and it weighs 75 lbs. Regular maintenance as per the owner's manual is recommended.
Technical Specifications
- Model Number: 917.388930
- Product Type: Walk Behind Mower
- Engine: 6.0 horsepower Briggs & Stratton 4-cycle engine, model 122K02-0577-E1
- Engine Design: Overhead valve
- Starting Mechanism: Recoil start
- Fuel Capacity: 1.6 quart, uses regular unleaded gasoline
- Cutting Deck Width: 21"
- Discharge Type: Rear discharge
- Cutting Height: Adjustable between 1-1/4" to 3-3/4" in 9 settings
- Cutting Deck Material: Rust resistant steel
- Drive System: Manual push
- Wheel Sizes: 8" front wheels, 12" rear wheels
- Safety Features: Operator presence control bar, rear deflector shield
- Dimensions: 43" x 21" x 38"
- Weight: 75 lbs
Warranty
The Craftsman Walk Behind Mower model 917.388930 comes with a 2-year full warranty. This warranty covers any faults or malfunctions that may occur during this period under normal use conditions. To claim the warranty, owners should refer to the owner's manual for specific instructions, which typically involve contacting the manufacturer or retailer with proof of purchase and details of the issue at hand. It is important to note that regular maintenance, as recommended in the owner's manual, should be performed to keep the product in good working condition and may be required for warranty claims.
