1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.388952
Background
The Craftsman Walk Behind Mower 917.388952, produced by Roper Corp for Sears, is a gasoline-driven rotary lawn mower. The mower is equipped with a Briggs & Stratton 6.5 horsepower engine that includes primer and throttle control functionality. The cutting width of the mower is 21 inches and it offers adjustable cutting height, ranging from 1 to 3 inches. The mower is versatile, with capabilities to mulch, bag at the rear or discharge from the side. The mower has 7 inch wheels at the front and 8 inch wheels at the back, and weighs 70 lbs.
In addition to its primary lawn mowing functions, the Craftsman Walk Behind Mower 917.388952 has a control bar that ensures the operator's presence, and a handle that can be folded for storage. The handle height can also be adjusted to suit the operator's comfort. The mower is equipped with a Briggs & Stratton 6.5 horsepower engine that uses regular unleaded gasoline and SAE 30 oil, and has a Champion RJ19LM/J19LM spark plug with a 0.030" gap. The mower's cutting system uses a steel mowing deck of 21 inches. For maintenance, the mower should be cleaned after each use and the oil, air filter, and spark plug should be replaced periodically. The blade should be inspected and sharpened or replaced as needed.
Technical Specifications
- Model Number: 917.388952
- Product Type: Walk Behind Mower
- Engine: Briggs & Stratton 6.5 hp OHV with primer and throttle control
- Cutting Width: 21 inches
- Cutting Height: 1-3 inches adjustable, 9 position
- Mulching Capable: Yes
- Rear Bagging Capable: Yes
- Side Discharge Capable: Yes
- Wheel Size: 7 inch front, 8 inch rear
- Weight: 70 lbs
- Handle: Folding handle for storage
- Engine Model: 123K02-0541-E1 Briggs & Stratton 6.5 horsepower engine with a recoil start
- Fuel: Regular unleaded gasoline and SAE 30 oil (SAE 5W-30 below 32°F)
- Oil Capacity: 20 oz
- Spark Plug: Champion RJ19LM/J19LM with a 0.030" gap
- Mowing Deck: 21 inch steel
- Discharge: Mulch, rear discharge, or side discharge
- Adjustment: Cutting height is adjustable from 1-3 inches in 9 increments via a single lever for each wheel
- Blade Fastening: Replaceable blade that is tightened with a bolt to 35-40 ft-lbs
- Handle Height: Adjustable
Warranty
The Craftsman Walk Behind Mower 917.388952 comes with a 2-year full warranty. This warranty covers any defects in material or workmanship that may arise within the allotted time frame. However, it's important to note that the warranty does not cover normal maintenance items such as oil changes, filters, blades, and tune-ups. Additionally, any damage resulting from improper use, abuse, or negligence is not covered under the warranty. To claim the warranty, it's generally required to contact the manufacturer or seller, in this case Sears, and provide relevant details about the defect. Please refer to your warranty documentation or contact customer service for detailed procedures.
