1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.38896
Background
Craftsman Walk Behind Mower 917.388960 is a push lawn mower which operates on gas. Developed by Roper Corp for Sears, this model holds a track record of providing a clean and even cut to your lawn. The mower is equipped with a 6.5 horsepower Briggs & Stratton 4-cycle overhead valve engine. The engine includes throttle and prime controls for better performance.
One of the key features of this model is its 21-inch steel blade that enables it to cover a wider area in a single sweep. The cutting height is customizable between 1-3/4 - 4 inches, with nine adjustable positions. The mower operates on a manual push transmission. The grass bag has a capacity of 2.4 bushels with a top load design. The mower runs on both front and rear wheels made of plastic, which measure 5-1/2 inches and 7 inches respectively. The mower weighs 75 lbs and its fuel tank can hold 1.6 quarts of unleaded gasoline. It uses SAE 30 or SAE 5W-30 oil type with a capacity of 20 ounces. The spark plug recommended for the mower is either Champion RJ19LM or J19LM, with a 0.030 inch gap. The mower is designed for walk-behind manual push operation, with speed adjusted according to the user's walking pace.
Technical Specifications
- Model Number: 917.388960
- Product Type: Walk Behind Mower
- Engine: 6.5 hp 4-cycle OHV with prime and throttle controls
- Cutting Width: 21 inches
- Cutting Height: 1-3/4 - 4 inches adjustable, 9 position
- Starter: Recoil
- Transmission: Manual push
- Blade: 21 inch steel
- Grass Bag: 2.4 bushel capacity top load
- Rear Wheels: 7 inch plastic
- Front Wheels: 5-1/2 inch plastic ball bearing
- Weight: 75 lbs
- Fuel Tank Capacity: 1.6 quarts unleaded gasoline
- Oil Type: SAE 30, SAE 5W-30
- Oil Capacity: 20 ounces
- Spark Plug: 0.030 inch gap
Warranty
The Craftsman Walk Behind Mower 917.388960 comes with a 2-year limited warranty provided by Sears. This warranty applies to defects in materials and workmanship, given that the product is used and maintained as per the guidance in the owner's manual. However, the warranty coverage does not include expendable parts that can wear out from normal use, such as standard maintenance services, oil changes, and tune-ups. Moreover, repairs needed due to operator abuse or negligence are also not covered. To claim the warranty, owners should contact Sears or consult the owner's manual for detailed instructions.
