5 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.38902
Background
The Craftsman Walk Behind Mower 917.389020 is a lawn mower designed for use in residential settings. The mower is equipped with a Briggs & Stratton 122T02-1308-B1 engine, a 163cc 2-cycle engine that utilizes unleaded regular gasoline with an octane rating of 87 or higher. The oil type recommended for use depends on the temperature, with SAE 30 recommended for temperatures above 32°F and SAE 5W-30 for temperatures below 32°F. The mower has an oil capacity of 20 oz and a fuel capacity of 1.6 quarts. The recommended spark plug for this model is the Champion RJ19HX, with a gap of 0.030".
The mower has a 21" multi-cut mowing deck, and the blade torque is between 35-40 ft-lbs. The cutting height can be adjusted from 1-3.75". In addition to these features, the mower has a convertible mulching, rear bagging, and side discharge function. It also comes with 7-position height adjusters. The mower has a folding handle for compactness. The dimensions of the mower are 70 lbs in weight, 63" in length, 21" in width, and 40" in height when folded.
Technical Specifications
- Model Number: 917.389020
- Product Type: Walk Behind Mower
- Engine: Briggs & Stratton 122T02-1308-B1
- Engine Capacity: 163cc, 2-cycle
- Start System: Electric start capable
- Fuel Type: Unleaded regular gasoline with 87+ octane
- Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil Capacity: 20 oz
- Fuel Capacity: 1.6 quarts
- Spark Plug: Champion RJ19HX, gap 0.030"
- Cutting Deck Size: 21"
- Blade Torque: 35-40 ft-lbs
- Cutting Height: Adjustable from 1-3.75"
- Cutting Options: Convertible mulching/rear bagging/side discharge
- Height Adjusters: 7-position
- Handle: Folding for compact storage
- Weight: 70 lbs
- Length: 63"
- Width: 21"
- Height: 40" when folded
Warranty
The Craftsman Walk Behind Mower 917.389020 comes with a 2-year full warranty against defects in material or workmanship when used for residential purposes. If the mower is used commercially, the warranty coverage is limited to 90 days. To claim the warranty, you would typically need to contact the manufacturer, Sears, providing them with details about the defect or issue that has arisen. Remember to keep your proof of purchase as it might be required to confirm the product's eligibility for warranty coverage.
