1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.38905
Background
The Craftsman Walk Behind Mower 917.389050 is a gas-propelled push lawn mower. The mower is equipped with a 163cc Briggs & Stratton 675 series engine which provides the necessary power for the operation. It also features ready start technology, which facilitates easy starting of the mower. The 22" steel deck allows for a wide cutting path with each pass.
This walk behind mower has variable speed rear wheel drive that can be adjusted based on the operator's preference and the conditions of the lawn. The mower deck is adjustable with 6 positions, allowing the cutting height to range from 1.25" to 3.75". There is also a 2-in-1 rear bagging system, which provides the option to either mulch or bag the clippings. The mower also includes a washout port for quick cleaning. Other features of the mower include foam padded handles for comfort, a dust blocking engine cover, and a zone start safety system.
Technical Specifications
- Model Number: 917.389050
- Product Type: Walk Behind Mower
- Engine: 163cc Briggs & Stratton 675 Series
- Cutting Width: 22 inches
- Cutting Height: Adjustable from 1.25 to 3.75 inches in 0.5 inch increments
- Rear Wheel Size: 11 inches
- Drive Type: Variable speed rear wheel drive
- Mower Deck Material: Steel
- Clipping Disposal: 2-in-1 system allowing for mulching or bagging
- Starting System: Ready Start technology
- Safety System: Zone Start, requiring the operator to squeeze a lever on the handle to start the mower
- Additional Features: Foam padded comfort grip handles, dust blocking engine cover, easy access washout port for quick cleaning of the mower deck
Warranty
The Craftsman Walk Behind Mower 917.389050 comes with a 2-year limited warranty that covers any defects found in the materials and workmanship, given the product is used for non-commercial purposes. This warranty is only applicable to the original purchaser and does not cover any damage arising from improper usage, lack of maintenance, or normal wear and tear. As for the engine warranty, it is separately covered by Briggs & Stratton. To claim the warranty, the owner will likely need to provide proof of purchase and contact the manufacturer directly, although specific instructions for claiming the warranty are not provided in the context.
