5 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.389061
Background
The Craftsman Walk Behind Mower 917.389061 is a gas-powered lawn mower that was manufactured by Roper Corp for Sears under the Craftsman brand. This mower is self-propelled and features a 21-inch cutting deck along with a Briggs & Stratton engine with a torque of 6.75 ft-lb.
The mower is designed for residential yard maintenance and is capable of efficiently trimming medium-sized yards due to its 21-inch steel cutting deck. It is powered by a 6.75 ft-lb Briggs & Stratton engine and uses a recoil pull start mechanism. The mower's variable speed rear wheel drive system offers three different speeds, allowing the operator to adjust according to their preference. It also has a fuel tank with a capacity of 1 gallon, which contributes to a longer running time before refueling is needed. The cutting height can be adjusted between 1 and 3 inches through the single-point height adjustment lever. This mower is equipped with a stop switch for the engine, which allows the operator to immediately shut off the mower if required.
Technical Specifications
- Model Number: 917.389061
- Product Type: Walk Behind Mower
- Manufacturer: Sears
- Manufactured in: United States
- Released: 2015
- Engine: 6.75 ft-lb gross torque Briggs & Stratton
- Cutting Width: 21 inches
- Cutting Height: Adjustable, 1-3 inches
- Drive System: Variable speed rear wheel drive
- Start Method: Recoil pull start
- Fuel Type: Gasoline
- Fuel Capacity: 1 gallon
- Wheel Size: 7 inch front wheels, 8 inch rear wheels
- Deck Material: Steel
- Product Weight: 160 lbs
Warranty
The Craftsman Walk Behind Mower 917.389061 is accompanied by a 2-year limited warranty. This warranty encompasses defects in materials and workmanship when the product is used for non-commercial purposes. To claim the warranty, it is necessary to provide proof of purchase and maintenance records. It is important to note that the engine warranty is separately managed and maintained by Briggs & Stratton.
