2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.370670
Background
The Craftsman Walk Behind Mower 917.370670 is a gas-powered lawn mower produced by Sears Brands. It is equipped with a 22" multi-cut blade and a Briggs & Stratton 700 Series engine that delivers 6.75 ft-lbs of torque. With a fuel tank capacity of 1.6 quarts and an oil capacity of 20 oz, the unit is capable of extended run times. The mower features a steel deck and adjustable cutting heights ranging from 1-3/4" to 4" in 7 increments. This model also offers multi-function capabilities, allowing users to choose between mulching, rear bagging, or side discharging their clippings.
The Craftsman Walk Behind Mower 917.370670 incorporates an operator presence control bar and a variable speed front wheel drive for easy operation. The unit also includes an 8" rear wheel and a folding handle for compact storage. The mower operates by holding down the operator presence control bar and pulling the starter cord. It is equipped with an automatic choke for easy starting. The front wheel drive speed is controlled by the drive control bar, which adjusts the speed based on how close it is pulled to the handle. Regular maintenance of this mower includes checking/changing the engine oil, cleaning/replacing the air filter, replacing the spark plug, and sharpening or replacing the blade as needed.
Technical Specifications
- Model Number: 917.370670
- Product Type: Walk Behind Mower
- Engine: Briggs & Stratton 128T02-1270-B1
- Engine Displacement: 126cc
- Engine Power: 6.75 ft-lbs torque
- Fuel Tank Capacity: 1.6 Quarts
- Oil Type: SAE 30 (above 32°F); SAE 5W-30 (below 32°F)
- Oil Capacity: 20 oz
- Blade Size: 22" multi-cut
- Deck Material: Steel
- Cutting Height: 1-3/4" - 4" in 7 adjustments
- Mulching Capability: Yes
- Rear Bagging Capability: Yes
- Side Discharge Capability: Yes with attachment
- Drive Type: Variable speed front wheel drive
- Wheel Size: 7" front, 8" rear
Warranty
The Craftsman Walk Behind Mower 917.370670 is covered by a 2 year limited warranty. This warranty specifically covers any defects in both materials and workmanship that the product might have. However, it is important to note that the warranty does not extend to normal wear parts such as belts, blades, and filters. Additionally, any issues arising from improper use, maintenance, or modifications of the mower are also not covered under the warranty. To claim the warranty, customers should contact Sears Brands directly, providing details of the defect and proof of purchase.
