Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Background and Identification
The Oxitest Plus7 is a pulse oximeter tester made by Datrend Systems, Inc. Pulse oximeters are non-invasive devices used to monitor a patient’s oxygen saturation. Datrend Systems is a biomedical engineering company that produces biomedical testing equipment.
The Oxitest Plus7 is a hand-held, battery-powered model designed to test pulse oximeters and their optical sensors. Many problems with pulse oximeters are due to partial or complete failure of the oximeter’s sensors. Sensors include the photosensor, light-transmitting elements (LEDs), the cable, or the connector. To use the Oxitest Plus7, place a pulse oximeter sensor on the Oxitest’s probe. The pulse oximeter sensor simulates a specified oxygen saturation level with a given signal strength (pulse amplitude) and heart rate. The Oxitest Plus7 then transmits an optical signal to the pulse oximeter sensor to test if the parameters measured by the pulse oximeter match those set by the Oxitest Plus7.
The Oxitest Plus7 pulse oximeter tester provides nine preset simulations for testing pulse oximeters under many clinical conditions. Test results can be printed, downloaded to a PC, or downloaded to an automated tester for documentation.
The Oxitest Plus7 includes the name “Oxitest” printed in large white font next to the words “Plus7” printed in italics. The manufacturer’s name, “Datrend Systems, Inc.,” is printed in black font in the bottom center of the device’s front face.
Technical Specifications
Saturation (SpO2 ):
Masimo, Mindray, Nellcor, and Nellcor OEM's (e.g., Critikon; Protocol; Philips; etc.):
- Variable from 35% to 100% in steps of 1%
- SpO2 presets at 35, 70, 80, 90, 93, and 97%
Selected EnviteC, Hewlett-Packard, Nihon Kohden, and Philips models:
- Variable from 55% to 100% in steps of 1%
- SpO2 presets at 55, 70, 80, 90, 93, and 97%
All other manufacturers and models:
- Variable from 70% to 100% in steps of 1%
- SpO2 presets at 70, 80, 90, 93, and 97%
SpO2 Accuracy:
All supported oximeters except Datex and Invivo oximeters:
- 55 to 100% SpO2: ±1% at specified SpO2 presets
- 35% SpO2: ±2%
- ±1% at 97, 93% SpO2
- ±2% at 90, 80, 70% SpO2
Heart Rate:
Variable from 20 to 250 beats per minute (BPM) in 1 BPM steps
- Presets: 30, 60, 90, 120, 180, 240 BPM
- Accuracy: ± 1 BPM
Pulse Amplitude:
Variable from zero (no blood flow) to 100% (normal adult pulse) in 1% steps.
- Presets: 100%, 30%, 10%, and 5%
- Accuracy: ± 1%
Signal Artifact:
Four preset simulations: Movement Tapping (Spike artifact) Shivering (Tremor artifact) Shake Table (2.5Hz Sinewave)
Serial / Printer Interface:
- Mechanical: 5 Pin Mini-DIN
- Electrical: Bi-directional RS-232. 9600 baud, 8 bits, no parity, 1 stop
Power Supply:
- Battery: 7.2V rechargeable.
- Capacity: 1.4 Ah
- Battery life: 40 hours continuous
Additional Information
Datrend Oxitest Plus7 Product Page
