Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Background
The Drager Narkomed 2A is an anesthesia system that was produced from 1982 through 1988. The Narkomed 2A was built off the strengths of the model 2. In the 2A, the central alarm panel was reconfigured with a digital display, an electronic respiratory monitor, and oxygen analyzer. This device was the first anesthesia machine that linked individual monitors to a central alarm display via electronic communication.
The Narkomed 2A allows for the administration of anesthetic and non-anesthetic gases to patients. If the machine is equipped with vaporizers, it is also capable of delivering anesthetic agents in the form of vapors in conjunction with these gases.
It has the the ability to monitor oxygen, breathing pressure, and respiratory volume. The ventilator allows the operator to mechanically control the patients ventilation. The operator can preset the tidal volume, inspiratory flow rate, I/E ratio and frequency. The electrically powered alarm panel contains numerous indicators to alert the operator in cases such as a disconnected breathing tube, high system pressure, oxygen supply failure and other potentially dangerous situations.
Identification
To identify the Drager Narkomed 2A, look on the top-right of the front of the device (just to the right of the N20 - Air Selector Switch and above the vaporizers). It should be labeled "Narkomed 2A." There should be a set of drawers and a table top. On the left of the Narkomed 2A there should be a CO2 Absorber. Some equipment such as the drawer set may vary from pictures.
For images to help identify the Drager Narkomed 2A, click here to access the Wood Library Museum of Anesthesiology website's description.
Additional sources:
Drager Narkomed 2A Service Manual
Technical Specifications
- Power Source: Four 1.5 voltalkaline batteries, SizeC
- PressureIndicator: NAD pressure gauge- minus 20cm H2O to plus 80cmH20
- PressureRelease: Muclippard valve
- Pneumatic Input andOutput: Femaleluer connectors
- Audible Alarm: Sonalert®4-28 voltsDC
- Electrical Connectors: Banana jack positive (+ red),Banana jack negative( - black)
Dimensions
- Weight - 325 lb (147 kg)
- Height - 68 in. (173 cm)
- Width - 40 in. (102 cm)
- Depth - 25 in. (63.5 cm)
- Shelf Area - 200 in sq (1,290 cm sq)
- Table top: Height: 34 in (86 cm) Area: 271 in sq (1,749 cm sq)
- Drawer Dimensions: Larger: 14x21x7 in (36x52x18 cm) - Smaller: 14x17x3 in (36x43x8 cm)
Features
- Standard Hypoxic Guard
- Standard O2 and N2O
- Holds up to 3 vaporizers
- Built in O2 volume and airway pressure monitors
Electronic specifications
- NADOxygen Monitor
- MeterLinearity: +- 1- 1.5% fullscale
- Response Time: 97%in 10seconds
- DriftRate: +- 1%fullscalein8hours
- Power Requirements: 3Mercury Batteries- 4.05 Veach.
- A l a r m D e l a y s o nN M 2 A
- 10 seconddelay: +- 1second
- 15second delay: +- 1.5 seconds
- 30second delay: +- 5.0seconds
- 60second delay: +- 6.0 seconds
- NM2A Power
- Primary: 117VAC, 60 Hz
- Secondary: 10-17VDC, unregulated
- Service Voltage: 5VDC, regulated
- Receptacles: 117 VAC (locatedinrear power supply)
- Receptacles: 12 VDC,unregulated for NADmonitors
- Reserve Power Supply: 12 Volt Lead-dioxide-acid,gelled battery
- Circuit Breaker CB1: 1AMP, 2pole, transformer primary
- Circuit BreakerCB2: 10 AMP,2 pole, 117VAC receptacles
- CircuitBreaker CB3: 2AMP, 1pole, back-upbattery
- Circuit Breaker CB4: 1.5 AMP,1 pole, ventilator, alarmpanel, flowmeter, lights, Oxymed
- CircuitBreakerCB5: 2AMP, 1pole, Spiromed
- Fuse: 1⁄2 AMP slowblow, 17 Volt secondary of transformer
Source:
inCAV Medical and Laboratory Equipment
Additional Information
For Routine Inspection Procedure, see page 5-2 of the Drager Narkomed 2A Service Manual. You can also look at these sites for specifications and images:
MedWrench: Information on service companies, forums for questions, and parts resources
Operating Principles of Narkomed Anesthesia Systems (covering Narkomed models 2A, 2B, 2C, 3, and 4)
Wood Library Museum of Anesthesiology website: Description and catalog of the Narkomed 2A
