Dremel 8200 Disassembly
2 Answers 3 Score |
Collet Nut Frozen on Shaft |
6 Answers 3 Score |
No Power coming from tool |
2 Answers 0 Score |
Opening the case of a Dremel Model 8200 |
2 Answers 1 Score |
Speed Control Triac Number |
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Dremel model 8200 is a cordless rotary multi-tool that can cut, route, grind, sharpen, polish, clean, carve, and engrave. The 8200 model features different speed settings and attachment options. It is sold with one attachment and 35 accessories. Dremel is an American brand of power tools that focuses on home improvement and hobby applications. Dremel is known for its rotary tools, like the Dremel 3000, 4000, and 8200, which are similar to the pneumatic die grinders used by toolmakers and moldmakers in the metalworking industry.
The Dremel 8200 features the “EZ Twist” nose cap, a collet lock-out function, a motor brake, and an RPM bandwidth between 5.0 and 33.0 revolutions per minute. The Dremel is sold with the Detailer’s Grip attachment, which is designed for improved tool control. The kit also includes a one-hour battery charger. The Dremel’s battery has a capacity of 1.5 Amps.
Identification
The Dremel 8200 includes a mostly black and grey plastic body with the name “Dremel” printed in capital letters along the side of the device. The model number “8200” is printed underneath the name “Dremel” on the side of the tool. The Dremel has medium blue buttons and a lever for controlling the tool’s rotating speed.
Technical Specifications
- Battery capacity: 1.5 Ah
- Charging time: 1 h
- Weight: 0,620 kg
- Length: 25 cm
- Width: 4.5 cm
- Depth: 6.5 cm
- No-load speed: 5.000 - 33.000 1/min
- Battery technology: Lithium-Ion / ECP
- Speed setting: Variable
- Accessory quick-change system: EZ Twist
- Sound power: 83 dB(A)
- Vibration: 1.1 - 5.6 m/s²
