Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
Ask a Question
There are no questions. Be the first to ask a question!
Background and Identification
The GE Tec 6 is a ventilator used by medical professionals to assist patients that need help breathing. It was released in 1998 by General Electric and produced by Datex-Ohmeda, a subsidiary company of GE. This model is only compatible with Desflurane gas, as is printed on the face of the device.
The GE Tec 6 is a large semi-rectangular box with a black top and off-white body. The color scheme is white and black, with blue accents and some stainless steel hardware. All of the displays and controls are located on the front face of the device, with Datex-Ohmeda and the model (Tec 6 Plus) printed along the top of the face in white. There are vents located along the side of the device. An indicator on the front shows the levels of desflurane in the attached tanks.
Technical Specifications
  • Voltage requirement: 100 to 120V AC 50/60 Hz | 220 to 240V AC 50/60 Hz
  • Concentration range: 1 to 18%
  • Anesthetic Agent: Des / Desflurane
Dimensions
Weight: 21 lbs (9.5 kg)                Depth: 9.25 in (235 mm)
Width: 4.33 in (110 kg)                Height: 9.84 in (250 mm)
Performance
  • Scale: 1% from 1 to 10% | 2% from 10 to 18%
  • Calibrated flow range at 21 ± 2° C: 0.2 to 10 liters/minute
  • Accuracy at 5 liters/min O2: ± 0.5% v/v of delivered agent or ± 15% dial setting (whichever is greater)
  • Liquid capacity: 390 ml nominal volume (indicated on level display) | 240 ml refill capacity indicator nominal ml reserve (not indicated on level display)
  • Flow resistance: Less than 50 cm H2O at 5 liters/minute of O2 at 21 °C | Less than 250 cm H2O at 15 liters/minute of O2 at 21 °C
  • Battery: Duracell MN 1604 or VARTA Energy 2000
  • Operating temperature range: 18 °C to 30 °C (64 °F to 86 °F)
  • Operating humidity range: 30% to 75% relative humidity (non-condensing)
  • Storage temperature range: -40 °C to 60 °C (-40 °F to 140°F)
  • Storage relative humidity range: 0% to 95% relative humidity at 40 °C (non-condensing)
  • Storage atmospheric pressure: 70.0 to 106.0 kPa
Additional Information
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 308
