Guides
Troubleshooting
If you are having difficulties with the Gateway LT2514u, try referring to the troubleshooting page.
Background and Identification
The Gateway LT2514u, is a netbook that is packaged and sold by Acer. Launched in 2010 it was powered by Intel Atom N450 with Windows XP as its primary system. It is black in color and weighs 2.43 lbs with the physical dimensions of 10.17” x 0.94” x 7.24”.
The Gateway LT2514u comes with 1 GB of RAM from the factory. However, it has the ability to hold 2 GB of ram. You can do the upgrade by following our replacement guide.
The Gateway LT2514U comes with a 160GB of storage place. However you can purchase replacement hard disk drives with up to 1TB capacity. If you want to replace the HDD yourself, you can follow our replacement guide.
Specifications
GeneralClassNetbook
Operating SystemWindows XP
BodyDimensions10.17 in x 0.94 in x 7.24 in
Weight1.10 kg (2.43 lb)
ColorBlack
DisplaySize10.1 inches
ProcessorNameIntel Atom N450
Frequency1.66 GHz
Cores1 per processor
CacheL1 Cache: 64 kb, L2 Cache: 1 - 2 MB
Architecture64-bit
ChipsetIntel NM10 Express
GraphicsTypeIntegrated card
NameIntel GMA 3150
MemoryCapacity1 GB (upgradable to 2 GB)
TypePC2-5300/6400 DDR2 200pin SDRAM SODIMM
StorageCapacity160 GB (upgradable to 1 TB)
TypeHard Disc (HDD)
InterfaceSATA
NetworkingLAN100 mpbs
WifiYes (802.11b, 802.11g, 802.11n)
InfraredNo
PortsUSB3 v2.0 ports
VGAYes
LAN EthernetYes
ESataNo
FireWireNo
Microphone3.5 mm
Headphone3.5 mm
Card ReaderSD, MMC
CD/DVD DriveNo
Docking Station PortNo
DevicesCameraYes, 1.3 megapixels
MicrophoneYes
BatteryTypeLi-Ion
Capacity4400 mAh
Battery Life4 Hours
Additional Information
Gateway LT2514u Specification
Gateway LT2514u User Guides
Gateway LT25 Parts
Brian Garver
839 Reputation
6 Guides authored
USF Tampa, Team 3-2, Sullivan Fall 2016 Member of USF Tampa, Team 3-2, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G2
3 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 15
All Time: 1,502
