1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
GP5500
Background
The Generac GP5500 is a portable generator that operates on gasoline. Manufactured by Generac Power Systems, a Wisconsin-based firm specializing in backup power generation, the GP5500 was introduced in 2019. This generator is designed to supply 5,500 peak watts and 4,375 running watts of electrical power.
The GP5500 features a 389 cc Generac OHV engine and a steel frame with integrated handles for transportation. Weighing around 118 pounds, it operates at a noise level of 69 dBA from a distance of 23 feet. The GP5500 can be powered by gasoline with an octane rating of 87 or higher, or by propane fuel. Its fuel tank capacity is 5.8 gallons of gasoline, which allows for approximately 10.5 hours of operation at 25% load. When using a 20 lb propane tank, the generator can run for about 8.5 hours. The generator is equipped with two 120V 20A household outlets and one 120V/240V 30A twist lock outlet. Additionally, it has a digital data center for displaying the running time and reminders for maintenance. The generator also includes features such as automatic shutdown in case of overload, auto shutoff for low oil, and a spark arrestor.
Technical Specifications
- Model Number: GP5500
- Product Type: Portable Generator
- Manufacturer: Generac Power Systems
- Release Year: 2019
- Peak Power: 5,500 watts
- Running Power: 4,375 watts
- Engine Type: 389 cc Generac OHV engine
- Frame: Steel frame with integrated handles
- Weight: 118 pounds
- Noise Level: 69 dBA from 23 feet away
- Power Outlets: Two 120V 20A household outlets and one 120V/240V 30A twist lock outlet
- Fuel Type: Gasoline (87 octane or higher) or Propane
- Fuel Tank Capacity: 5.8 gallons of gasoline
- Run Time: 10.5 hours at 25% load (Gasoline), 8.5 hours with a 20 lb propane tank (Propane)
- Display: Digital data center (Displays running time and maintenance reminders)
- Safety Features: Overload protection (auto shut-off), low oil auto shut-off, and a spark arrestor
- Use Case: Portable use at homes, cabins, job sites, or camping
- Portability: Compact design with fold-down handles and wheels
- Ventilation Recommendation: At least 15 feet away from buildings when in use
- Power Capacity: Can handle surges from major appliances such as refrigerators and furnaces, can power several lights, appliances, and tools simultaneously.
Warranty
The Generac GP5500 portable generator comes with a 2-year limited warranty. This warranty covers any defects in materials and workmanship that may arise during the given period. In order to claim the warranty, it's usually necessary to contact the manufacturer directly, providing them with details about the issue as well as proof of purchase. However, the specific process may vary, so it's recommended to check the warranty card or user manual for exact details on how to lodge a warranty claim.
