Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Background and Identification
The Getemed VitaGuard VG 300 and 310 models are heart rate, apnea, and respiration monitors made by Getemed. Getemed Medizin is a producer of medical devices in the following categories: cardiac function diagnostics, ambulatory patient monitoring, and telemonitoring. The VG 300 and 310 models can be used for monitoring vital signs in clinical and home environments. The 310 pulse oximeter is also designed for applications where movement of the patient is necessary.
The VG 300 and 310 models feature graphical LCD displays that present measured parameters, alarm settings, waveforms, and status messages. These devices also include 72 hours of trend memory and an 8-hour full-disclosure memory. If the patient’s pulse rate or oxygen saturation moves outside the preset limits, the device provides an audible and visual alarm.
The VG 300 and 310 monitors can be powered by either four 1.5-Volt alkaline batteries or with an external 9-Volt power adapter. With fully charged batteries, the monitor can operate for up to 24 hours.
For the VG 310 model, the name “VitaGuard VG 310” is printed in blue font in the upper right-hand corner of the device’s front face.The VG 300 model looks visually similar but includes the name “VitaGuard VG 300” in the upper right-hand corner of the monitor’s front face. The manufacturer’s name, “Getemed'' is printed vertically in white lowercase font on the left-hand side of the device's front face. Four arrow buttons are located on the right-hand side of the device’s display.
Technical Specifications
General:
- Weight with power pack: Approx. 700 g
- Dimensions: 13.5 x 20.5 x 4.5 cm
- Casing material: ABS
- Power supply:
- Power pack (4.8 V, NiMH) or 4 x batteries (1.5 V, LR6, alkaline)
- 9 V power adapter NA 3000-2
- Power adapter NA 3000-2: Input: 100 – 240 V, 50 – 60 Hz, 400 mA / Output: 9 V d.c., 1.5 A
- Power pack recharge time: < 6 h
- Operating time: > 8 hours with alkaline batteries or NiMH power pack
- Replace battery message: Message on LCD display
- Battery exhaustion message: Visual and acoustic warning
- Keys: 6 pushbuttons
- SpO2 connector: 14-pin mini-ribbon connector, type BF input
- USB connector Mini USB to connect with a PC
- AUX connector features:
- RS232 interface for modem or online output
- External alarm unit output
- Nurse call unit output
- 2 analog inputs (AUX 1 & 2)
- Display elements: 4 LED’s and a graphical LCD display (320 x 240 dots) with backlight when powered by external or automobile power adapter
- Alarm warnings: Visual and acoustic as per DIN EN 60601-2-49 and IEC 601-1-8
Pulse Rate Monitor:
- Method Pulse: oximetry
- Pulse rate range: 25 – 240 /min
- Resolution: 1 /min
- Accuracy: ± 3 digits without motion ± 5 digits during motion
- Bradycardia alarm settings: 30, 35 ... 175, 180 /min
- Tachycardia alarm settings: 100, 105 ... 250, 255 /min
- Signal recognition: Green LED and selectable beep tone
SpO2 Monitor:
- SpO2 range: 1 – 100 %
- Resolution: 1 %
- Accuracy: ± 3 digits for SpO2 above 70 %
- Alarm settings: Selectable from 50 – 100 %
- Sensitivity: Minimum (APOD), Standard, Maximum (APOD = Adaptive Probe Off Detection)
Memory:
- Storage functions: Event, trend, full-disclosure and compliance memory
- Storage capacity:
- Approx. 200 events, depending on pre-alarm and post-alarm settings
** 72 h trend, 8 h full-disclosure
- Stored data: SpO2, pulse rate, signal IQ, plethysmogram, perfusion index, status, 2 analog inputs
Classifications:
- Product classification: IIb as per MDD 93/42/EEC
- Electrical classification: Class II as per DIN EN 60601-1
- EMC classification: Group 1, class B as per DIN EN 60601-1-2
- Ingress protection: IP 21 as per DIN EN 60529
Environmental Conditions:
- Operating temperature range: 5 – 40 °C
- Operating humidity range: 5 – 95 %, non-condensing
- Altitude: -300 m to +5000 m
- Storage temperature range: -40 to +70 °C
