CMOS Battery
1 Answer 0 Score |
Why does vertical line appear on document using ADF as source? |
2 Answers 0 Score |
I have a bad ADF |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The HP Officejet Pro 8625 is an all-in-one printer manufactured by HP in 2014 that can print, scan, copy, fax and access the web. It is black in color and weighs roughly 26 pounds. The printer has never been recalled and is currently not discontinued.
The HP Officejet Pro 8625 is a mid-tier printer between the Officejet Pro 8620 and the HP Officejet 8630. The HP Officejet Pro 8625 is internally identical to the HP Officejet Pro 8620 and the HP Officejet Pro 8630, so the replacement guides for the HP Officejet Pro 8625 should work similarly for those printers as well.
Identification
It can be distinguished from similar printers by finding the name “HP Officejet Pro 8625” on the left side of the front panel.
