Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background and Identification
Note that this printer is mechanically identical to the Officejet Pro 8620, so the instructions and images provided there will also apply to this printer.
The HP Officejet Pro 8630 is an all-in-one color printer, meaning it can print, scan, copy, and fax. Users can print from their smartphone, tablet, or notebook using wireless options, NFC touch-to-print technology, or Ethernet for wired connectivity. The 8630 model includes an additional 250-sheet tray and an extra set of color ink cartridges,
The HP Officejet Pro 8630 features double-sided printing and an automatic document feeder that allows multiple pages to be copied or scanned without manually loading each page. The scanner can scan pages up to 8.5- by 14-inches and has a scan to email function that allows scanned documents or photos to be emailed directly from the printer to email recipients. The printer also features a borderless printing option, meaning photos are printed up to the edge of the paper.
The HP Officejet Pro 8630 can be identified by the name “HP Officejet Pro 8630” located in the upper left-hand corner of the printer’s front. The HP logo, which includes the letters “HP” in lowercase font surrounded by a silver circle, is located above the printer’s name in the left-hand corner. The device also includes a 4.3-inch touchscreen display in the upper right-hand corner of the printer’s front.
Technical Specifications
General:
  • Printing Technology: Ink-jet - color
  • Monthly Duty Cycle (max): 30000 pages
  • Office Machine Features: Scan to e-mail
  • Display Features: Touch screen
  • Fax Type: Plain paper
  • Display Diagonal Size: 4.3"
  • Recommended Monthly Volume: 250 - 1500 pages
  • Manufacturer: HP
Connectivity:
  • Wireless Ready: Yes
  • Mobile Printing Capability: Apple AirPrint, HP ePrint, wireless direct printing
Printer:
  • Inkjet Technology: HP Thermal Inkjet
  • Ink Cartridge Configuration: 4 cartridges (1 each: cyan, magenta, yellow, black)
  • AirPrint Enabled: Yes
  • First Print Out Time B/W: 12 sec
Memory:
  • Standard Memory: 128 MB
Copying:
  • Max Copying Speed: Up to 34 ppm (mono) / up to 34 ppm (color)
  • Max Copying Resolution: Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (color)
  • Max Copying Speed B/W: 34 ppm
  • Max Copying Speed Color: 34 ppm
  • Max Copying Resolution B/W: 1200 x 600 dpi
  • Max Copying Resolution Color: 1200 x 600 dpi
  • Max Document Enlargement: 400 %
  • Max Document Reduction: 25 %
  • Automatic Duplexing: Yes
  • Maximum Copies: 99
  • Copying Features: ID Card Copy
Display:
  • Display Diagonal Size (metric): 10.9 cm
  • Features: touch screen
Miscellaneous:
  • Microsoft Certifications: Compatible with Windows 7
  • Consumables Included
    • 1 x cartridge (pigmented black) - up to 1000 pages - HP 950
    • 1 x cartridge (pigmented cyan) - up to 700 pages - HP 951
    • 1 x cartridge (pigmented magenta) - up to 700 pages - HP 951
    • 1 x cartridge (pigmented yellow) - up to 700 pages - HP 951
  • Color Category: black
  • Included Office Machine Accessories: USB cable, phone cable
Power:
  • Power Consumption Sleep: 2.2 Watt
  • Power Consumption Standby: 6.8 Watt
  • Power Consumption Operational: 35 Watt
Environmental Standards:
  • EPEAT Compliant: EPEAT Bronze
  • ENERGY STAR Certified: Yes
Printing:
  • Max Printing Resolution: Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (color)
  • Max Printing Speed: Up to 34 ppm (mono) / up to 34 ppm (color)
  • Max Resolution B/W: 1200 x 1200 dpi
  • Max Resolution Color: 4800 x 1200 dpi
  • Printer Drivers / Emulations: PCL 3, PCL 3 GUI
  • Max Printing Speed B/W (ppm): 34 ppm
  • Max Printing Speed Color (ppm): 34 ppm
  • Ink Palette Supported (Colors): Cyan, magenta, yellow, black
  • First Print Out Time Color: 13 sec
  • Color: 4-ink
Dimensions and Weight:
  • Width: 19.7 in
  • Depth: 18.5 in
  • Height:15.7 in
  • Weight: 35.01 lbs
Header:
  • Brand: HP
  • Product Line: HP Officejet Pro
  • Model: 8630 e-All-in-One
  • Localization: English, French, Spanish
  • Country Kits: Canada, United States
Additional Information
Robert Backhaus
1,030 Reputation
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 30
All Time: 4,724
