Detaching the HP Photosmart 2575 All-in-One's control panel
8 Answers 3 Score |
Why won't the printer grab the heavier paper? |
6 Answers 4 Score |
How do you fix a carriage jam? |
3 Answers 4 Score |
says out of paper |
1 Answer 2 Score |
How to fix Error code |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background and Identification
Hewlett-Packard (HP) is an information technology company located in San Jose, California. Their products include hardware, software, hyper-converged infrastructure, network security, cloud services, etc. The HP PhotoSmart 2575 is an All-in-One Printer, Scanner, Copier, and includes HP 337 Black Inkjet Print Cartridge (11 ml), HP 343 Tri-colour Inkjet Print Cartridge (7 ml), HP Image Zone photo & imaging software, setup booklet, user’s guide, power supply, and a power cord.
The HP PhotoSmart 2575 All-in-One Printer can be identified by the product number Q7215B and is colored in dark grey/blue and silver along the top. The HP logo is located on the top of the printer, and the buttons and screen are located on the top right of the machine.
Technical Specifications
GENERAL
- Device Type: Multifunction printer
- Printing Technology: Ink-jet - color - photo
- Monthly Duty Cycle (max): 3000 impressions
- Office Machine Features: Print from memory card
- Fax Type: Plain paper
- Display Diagonal Size: 2.5"
- Manufacturer: HP
MEMORY
- Standard Memory: 64 MB
- Max Supported Memory: 64 MB
- Supported Flash Memory: CompactFlash, IBM Microdrive, Memory Stick, MultiMediaCard, SD Memory Card, xD-Picture Card, Memory Stick Duo, USB flash drive, miniSD
PRINTER
- Inkjet Technology: HP Thermal Inkjet
- Ink Cartridge Configuration: 1 black cartridge, 1 color cartridge (cyan, magenta, yellow)
- Technology: Ink-jet
- Ink Type: HP Vivera Inks
- Connectivity Technology: Ethernet and USB
- Direct Printing Specifications: PictBridge
- Type: Multifunction printer
POWER
- Power Consumption Operational: 70 Watt
DISPLAY
- Display Diagonal Size: 2.5 in / 6.4 cm
COPYING
- Max Copying Speed: Up to 30 ppm (mono) / up to 24 ppm (color)
- Max Copying Resolution: Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (color), Up to 600 x 1200 dpi (mono) / up to 4800 x 1200 dpi (color), Up to 1200 x 4800 dpi (mono) / up to 4800 x 1200 dpi (color)
- Max Copying Speed B/W: 30 ppm
- Max Copying Speed Color: 24 ppm
- Max Copying Resolution B/W: 600 x 1200 dpi, 4800 x 1200 dpi, 1200 x 4800 dpi
- Max Copying Resolution Color: 4800 x 1200 dpi
- Grayscale Half-Tones: 256
- Max Document Enlargement: 400 %
- Max Document Reduction: 50 %
- Automatic Duplexing: none
- Maximum Copies: 50
- Copying Features: BorderFree, fit to page
SCANNING
- Max dimensions: A4 (21 cm x 29.7 cm)
RAM
- Installed Size: 64 MB
- Max Supported Size: 64 MB
PRINTING
- Max Printing Resolution: Up to 1200 dpi (mono) / up to 4800 x 1200 dpi (color)
- Max Printing Speed: Up to 30 ppm (mono) / up to 24 ppm (color)
- Max Resolution B/W: 1200 dpi
- Max Resolution Color: 4800 x 1200 dpi
- Printer Drivers / Emulations: PCL 3
- Max Printing Speed B/W (ppm): 30 ppm
- Max Printing Speed Color (ppm): 24 ppm
- Ink Palette Supported (Colors): Cyan, magenta, yellow, black
- Color: 4 or 6-ink, 6-ink
DIMENSIONS & WEIGHT
- Width: 17.3 in
- Depth: 14.3 in
- Height: 8.2 in
- Weight: 12.13 lbs
DOCUMENT & MEDIA HANDLING DETAILS
- Type: input tray, output tray
- Media Feeder Capacity: 100 sheets, 50 sheets
- Max Media Size: Legal (8.5 in x 14 in)
SOFTWARE
- Operating System Support: Apple Mac OS 9.1 or later, Apple Mac OS X 10.1.5 or later, MS Windows 2000, MS Windows XP
SPEED DETAILS
- Function: copying, printing
- Max Speed: 24 ppm, 30 ppm
- Size: Letter A
- Mode: B/W, B/W draft, color, color draft
POWER ADAPTER
- Input: 100 - 240V AC 1630 mA 50/60 Hz
- Output: 32V DC 1100 mA, 16V DC 1600 mA
- Part number: 0957-2175
