Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
TE1000-AVR
Background
The device is a highly versatile tool that is designed for floor breaking and has an ergonomic side handle to tackle wall breaking. Its applications include demolishing concrete and masonry at floor level or below waist level, renovating floors, removing tiles, removing tiles, and chiseling. This device has a maintenance-free brushless SR motor and triple-chamber lubrication for longer service intervals and tool lifetime. It has a low vibration due to the Hitili AVR sub-chassis system. The detachable supply cord makes for easy replacement of damaged or broken cords on the jostle. The power tool also includes an optional TE DRS-B dust removal system, which collects up to 95% of dust.
SAFETY
Hilti Products may only be operated, serviced, and maintained by trained, authorized personnel. The personnel must be informed about the device and aware of potential hazards. The product can include hazards if untrained personnel misuse the product.
- Wear ear protection
- Hold the power tool by insulated gripping surfaces, when performing an operation where the cutting accessory may contact hidden wiring or its cord
- Before using the device, check the working area for concealed electric cables or gas and water pipes. External metal parts of the power tool may give you an electric shock if you damage an electric cable accidentally.
* DO NOT use in damp settings.
Identification
The Hilti TE 1000-AVR is a large, bulky drill-like tool. The overall weight is roughly 30 lbs without any attachments. It is red and black with the Hilti logo marked on the sides. The tool also has a sticker including the serial and model numbers.
Technical Specifications
Working direction: Floor, Wall
Tool chuck type: TE-S
Weight according to EPTA-Procedure 01/2003 without battery: 27.6 lb.
Single impact energy: 19.2 ft-lbs
Rated current: 15 A
Full hammering frequency: 1950 impacts/minute
Max. chiseling performance: 476 in³/min
Dimensions (LxWxH): 28 x 5.6 x 12 in
Triaxial vibration for chiseling into concrete: 5.9 m/s² 1
Dust removal system available: TE DRS-B
A-weighted emission sound pressure level: 85 dB (A) 2
