2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
EC2510E
Background
The Hitachi EC2510E is a gas-powered air compressor that was first launched in September 2004. This 8-gallon, wheeled device is equipped with a cast iron pump that delivers consistent performance. It provides 9 CFM at 100 PSI of air flow, with a startup PSI of 116 and a maximum PSI of 145.
The control panel of the Hitachi EC2510E is integrated with the base plate, which safeguards the gauge, regulator, and plumbing while making the controls easily accessible. The device features an oversized oil level sight glass for convenient oil level monitoring. The EC2510E uses a pneumatic throttle instead of a cable, which eliminates failures arising from crimping or breaking. The air compressor also includes ball valve tank drains for easy draining and a flexible braided stainless steel exhaust tube to reduce vibration and impact damage.
Technical Specifications
- Model Number: EC2510E
- Product Type: Air Compressor
- Manufacturer: Hitachi
- Release Date: September 2004
- Engine: 5 HP
- Pump Speed: 3,200 RPM
- Air Flow: 9 CFM @ 100 PSI
- Startup Pressure: 116 PSI
- Maximum Pressure: 145 PSI
- Tank Capacity: 8 gallons
- Drain Type: Ball valve tank drain
- Throttle Control: Pneumatic
- Exhaust: Flexible stainless steel
- Oil Type: Synthetic
- Portability: Wheels
- Power Source: Gas-powered
- Weight: 144 lbs
- Dimensions: 41 x 19 x 31 inches
- Air Flow Capacity: 9 CFM
- Hose Length: 42.1 inches
Warranty
The Hitachi EC2510E air compressor comes with a 1-year warranty that covers defects in materials and workmanship. This warranty period begins from the date of the original purchase. If the product develops any faults due to defects in either materials or workmanship within this period, the manufacturer will rectify these issues at no additional cost. Additionally, there is a 30-day satisfaction guarantee offered. To claim the warranty, you would typically need to provide proof of purchase, such as a purchase receipt, and contact the manufacturer directly or the authorized dealer from whom the product was purchased. It's important to check and adhere to the terms and conditions of the warranty, as certain actions may invalidate it.
