1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
EC 129
Background
The Hitachi Air Compressor EC 129 is a portable air compressor. This product is primarily used for supplying air for various applications such as powering pneumatic tools and inflating tires. The portability aspect of this air compressor makes it a flexible tool that can be transported and used in different locations such as homes, automotive services, and light industrial environments.
The EC 129 model is equipped with a 1.5 HP induction motor and an oil-lubricated reciprocating air pump, capable of delivering 2.6 CFM at 90 PSI maximum pressure. Its tank, which can hold up to 2.6 gallons, is constructed from steel with a powder-coated finish that resists rust. The compressor is designed with a handle, onboard storage for accessories, and pneumatic tire wheels for easy transport around work sites. It can operate in both vertical and horizontal positions. The front-mounted control panel includes an on/off switch, pressure regulator, and air pressure gauge. An overload protector is integrated into the design to mitigate damage from overheating.
Technical Specifications
- Model Number: EC 129
- Product Type: Air Compressor
- Manufacturer: Hitachi
- Application: General purpose air supply, powering pneumatic tools, inflating tires
- Motor Power: 1.5 HP
- Air Delivery: 2.6 CFM at 90 PSI max pressure
- Tank Capacity: 2.6 gallons
- Max Pressure: 135 PSI
- Pump Type: Oil-lubricated reciprocating
- Power Supply: 120V, 60Hz
- Dimensions: 20 x 17 x 18 in
- Weight: 44 lbs
- Construction: Steel with rust-resistant powder coated finish
- Operating Position: Vertically or horizontally
- Additional Features: Carrying handle, onboard accessory storage, pneumatic tire wheels, front mounted control panel with on/off switch, pressure regulator, air pressure gauge, overload protector.
Warranty
The Hitachi Air Compressor EC 129 comes with a 1-year consumer warranty that covers defects in materials and workmanship. However, it is important to note that wear parts such as air filters are excluded from the warranty. To claim the warranty, users must provide proof of purchase and date. This warranty assures you of the product's quality and reliable operation, providing peace of mind as you use the compressor for your various needs.
