1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
EC 99S
Background
The Hitachi Air Compressor EC 99S is an electric air compressor that is produced by Hitachi Koki Co., Ltd. It is primarily used in home, hobby, and light professional environments. This air compressor is typically used for tasks such as filling tires, airbrushing, blowing dust, and operating air tools.
The Hitachi Air Compressor EC 99S operates on 800 watts and a voltage of 120V / 60Hz. It delivers air at a rate of 2.5 CFM at 90 PSI, and can reach a maximum pressure of 135 PSI. The capacity of the air tank is 1 gallon. It produces a noise level of 68 dB and measures 15 x 12 x 18 inches. The weight of the machine is 22 lbs. It is equipped with an oil-free piston pump, an aluminum cylinder head and crankcase, and a cast iron air tank with a powder coat finish. It also has an adjustable pressure regulator, a 6 foot power cord, and automatic restart functionality. The motors of the compressor are thermally protected to prevent overheating. It is primarily used for inflating tires, running small air tools, airbrushing, and other hobbyist projects. Its compact size makes it suitable for use in home workshops, garages, craft rooms, and for DIY applications.
Technical Specifications
- Model Number: EC 99S
- Product Type: Air Compressor
- Power: 800 watts
- Voltage: 120V / 60Hz
- Air delivery: 2.5 CFM @ 90 PSI
- Maximum pressure: 135 PSI
- Tank capacity: 1 gallon
- Noise level: 68 dB
- Dimensions: 15 x 12 x 18 inches
- Weight: 22 lbs
- Material: Aluminum cylinder head and crankcase, cast iron air tank with powder coat finish
- Additional Features: Adjustable pressure regulator, automatic restart after power interruption, thermally protected motors, oil-free piston pump.
Warranty
The Hitachi Air Compressor EC 99S comes with a limited warranty that lasts for one year. This warranty covers any defects that might occur in materials and workmanship of the product. It's important to note that this warranty is only valid if proof of purchase can be provided, and it does not extend to any damage that results from misuse or accidents. To claim the warranty, users should keep their receipt as proof of purchase and contact Hitachi in the event of a material or workmanship defect.
