1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
H65SD2
Background
The Hitachi H65SD2 is a demolition hammer, notable for its use in heavy-duty demolition work, such as chiseling and breaking up concrete. This corded electric tool, which was first released in April 2004, operates on a voltage of 110V, with a current of 10.8A and a maximum power output of 850W. The hammer weighs 40.8 lbs and employs an electro-pneumatic piston hammer mechanism, delivering an impact energy of 31 ft-lbs with approximately 1500 impacts per minute. The tool holder is designed for 1-1/8 inch hex.
One of the key features of the Hitachi H65SD2 is its 10.8 amp motor, which provides an impact energy of 31 ft-lbs. To enhance user experience, it has a uniquely designed main handle that helps in reducing vibration. The demolition hammer's durability is assured with features like metal-seated armature bearing that helps in reducing effects of vibration and heat on the motor, and auto-stop carbon brushes. Additionally, the hammer includes sealed grease lubrication, a rear-mounted auxiliary handle for improved control, a universal tool retainer compatible with both collared and non-collared bits, an elastomer wrapped main handle to minimize vibration, a rubber grip to prevent slipping, and a lock-on trigger for continuous operation. The tool comes with a carrying case for easier portability.
Technical Specifications
- Model Number: H65SD2
- Product: Demolition Hammer
- Power source: Corded electric
- Voltage: 110V
- Amperage: 10.8A
- Wattage: 850W max
- Hammer weight: 40.8 lbs
- Hammer mechanism: Electro-pneumatic piston hammer
- Blow energy: 31 ft-lbs
- Impacts per minute: 1500
- Tool holder: 1-1/8 inch hex
- Motor power: 10.8 amp
- Vibration reduction: Main handle design and metal-seated armature bearing
- Motor durability features: Auto-stop carbon brushes and sealed grease lubrication
- Additional handle: Rear-mounted auxiliary handle
- Tool compatibility: Collared and non-collared bits
- Grip features: Anti-vibration elastomer wrap and rubber overmolding
- Operation: Lock-on trigger for continuous operation
- Additional features: Carrying case
Warranty
The Hitachi H65SD2 Demolition Hammer comes with a 1-year limited warranty. This warranty includes a 30-day money-back guarantee from the date of purchase when bought new. To claim the warranty, it is essential to keep proof of purchase, which will be required in the warranty claim process. The specific details of what is covered under the warranty are not stated in the provided document, but typically, limited warranties cover any defects in materials or workmanship under normal use. For more detailed information, it is suggested to refer to the warranty clause provided by Hitachi at the time of purchase.
