2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
C10FCH
Background
The Hitachi C10FCH is a 10-inch sliding compound miter saw, a type of power tool used for making precise crosscuts and miter cuts at various angles. Manufactured by Hitachi Koki Co., Ltd., it was introduced in 2010.
The miter saw is equipped with a dual bevel sliding compound feature, allowing it to cut material up to 3-3/4 inches thick at 90 degrees and 2-3/4 inches thick at 45 degrees. The miter angle range is 0-57 degrees left and right, with positive stops at common angles, while the bevel range is 0-45 degrees left and right. The tool comes with a built-in laser marker to assist with cut alignment and a tall sliding fence capable of supporting crown molding vertically up to 5-1/2 inches tall. The sliding system uses steel linear ball bearings for a smoother sliding action. The 15-amp motor powers the 10-inch 24-tooth TCT saw blade at up to 4,000 RPM. The saw's base is constructed from aluminum die-cast material. The blade's position can be adjusted using a thumb-actuated lever on the side of the saw. The fence can be pivoted out of the way after each cut and the saw features a dust collection port for cleanliness.
Technical Specifications
- Model Number: C10FCH
- Product Type: Miter Saw
- Manufacturer: Hitachi Koki Co., Ltd.
- Release Year: 2010
- Tool Type: Dual Bevel Sliding Compound Miter Saw
- Saw Blade Diameter: 10 inches
- Maximum Cutting Thickness at 90 degrees: 3-3/4 inches
- Maximum Cutting Thickness at 45 degrees: 2-3/4 inches
- Miter Angle Range: 0-57 degrees (left and right)
- Bevel Range: 0-45 degrees (left and right)
- Special Features: Laser marker for cut alignment, Tall sliding fence for supporting crown molding up to 5-1/2 inches vertically, Steel linear ball bearing slide system
- Cut Capacity at 90 degrees: 3-3/4 inches height, 12 inches width
- Cut Capacity at 45 degrees: 2-3/4 inches height, 8-1/4 inches width
- Power: 15-amp electric motor, 4,000 RPM
- Base Material: Aluminum die-cast
- Additional Features: Dust collection port, Integrated carrying handles
- Weight: 65 pounds
- Dimensions: 27 x 23 x 18 inches
- Shipping Weight: 66 pounds
Warranty
The Hitachi Miter Saw C10FCH comes with a 5-year warranty. This warranty generally covers any defects in materials or workmanship that may occur under normal use and care during this period. If a defect arises, the procedure to claim the warranty typically involves contacting the manufacturer's customer service, providing proof of purchase like the original receipt or a warranty card, and describing the issue in detail. They may ask for the product to be sent for inspection or repair. Please consult your product manual or the manufacturer's website for specific details regarding warranty claim procedures.
