3 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
C10FSB
Background
The Hitachi C10FSB is a miter saw produced by Hitachi Koki Co., Ltd., initially released in 2010. Its design allows it to make a variety of cuts in materials such as wood, including cross cuts, miter cuts, bevel cuts, and compound cuts. It utilizes a 10-inch diameter carbide-tipped saw blade, capable of cutting through material up to 5-1/2 inches thick.
The C10FSB includes a quad-post slide system, designed to provide stability and accuracy when executing bevel and miter cuts. It has heavy-duty steel rails and linear ball bearings that enable the head to glide with ease. The miter angle can be adjusted between 0 to 52 degrees left and 0 to 60 degrees right, with positive stops at frequently used angles. Its bevel range is 0 to 45 degrees for both left and right. Other features include a 15-amp motor with a speed of 5,000 RPM, an electric brake for the blade, a large trigger switch, lock, table extensions for larger workpieces, and a bag for collecting sawdust and debris.
Technical Specifications
- Model Number: C10FSB
- Product Type: Miter Saw
- Blade Diameter: 10 inches
- Blade Arbor Size: 5/8 inches
- No Load Speed: 5,000 RPM
- Max Cutting Capacity (Miter/Bevel): 5-1/2 x 7-1/2 inches
- Max Cutting Capacity (Nested Crown): 5-7/8 inches
- Miter Angle Range: 0 - 52 degrees left, 0 - 60 degrees right
- Miter Positive Stops: 0, 15, 22.5, 31.6, 45, 60 degrees
- Bevel Range: 0 - 45 degrees left/right
- Motor Power: 15 amps
- Power Source: 120V AC
- Dimensions (DWH): 27 x 23 x 23 inches
- Weight: 52 lbs
Warranty
The Hitachi Miter Saw C10FSB comes with a warranty that spans over a period of 5 years, provided by Hitachi. This warranty covers any defects that may arise from the materials used in the product or from the workmanship. Additionally, specific wear items like the carbon brushes are covered under this warranty but for a shorter duration of 1 year.
